| Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
| brant |
Feb 11 2016, 07:39 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,212 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The materials used in a stock 914 engine do not like high compression.
Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers |
| ConeDodger |
Feb 11 2016, 09:06 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,476 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
The materials used in a stock 914 engine do not like high compression. Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers (IMG:style_emoticons/default/agree.gif) engine sealing becomes an issue. Cylinder head temperatures become an issue. Oil cooling which is important to consider separately from CHT becomes an issue. Your numbers, 100 HP/liter are doable, but I know only a couple builders who can make that live very long. At the raw number, 200-210HP, you might as well put a 3.2-6 in it as you've spent the money... |
| Mark Henry |
Feb 11 2016, 09:20 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The materials used in a stock 914 engine do not like high compression. Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers (IMG:style_emoticons/default/agree.gif) engine sealing becomes an issue. Cylinder head temperatures become an issue. Oil cooling which is important to consider separately from CHT becomes an issue. Your numbers, 100 HP/liter are doable, but I know only a couple builders who can make that live very long. At the raw number, 200-210HP, you might as well put a 3.2-6 in it as you've spent the money... (IMG:style_emoticons/default/agree.gif) To a point ... 100hp/liter is a crack pipe dream for a novice Type 4 builder. A Type 4 is an unforgiving bitch that will granade if you don't build it right. Your pistons and cylinders alone will cost $3440, I'd say you are easily well over $12K in parts alone. I know look at my signature line for my '67 bug. If the price doesn't scare you then look at my sig line again and what's going into my 914. Once you get to the cost of a super HP Type 4 in a 914, you may as well do a nice /6. But then if HP is all you are looking for... do a V8. |
Beebo Kanelle Type 4 mechanical compression ratio Feb 11 2016, 01:03 PM
914_teener
OK, here's a fun one for the novice to ponder... Feb 11 2016, 01:27 PM
Mark Henry Kind of funny way of asking what is the max HP a T... Feb 11 2016, 02:19 PM
colingreene Compression ratio is often set by quality of fuel.... Feb 11 2016, 02:22 PM
Dave_Darling Assuming you aren't actually trying to burn an... Feb 11 2016, 04:10 PM
r_towle 13:1 at 200 hp
Race fuel only.
Could not move the... Feb 11 2016, 04:14 PM
Beebo Kanelle Thank you one and all.
I'm afraid I wasn... Feb 11 2016, 04:35 PM
Steve Pratel
I'm afraid I wasn... Feb 11 2016, 10:11 PM
Mark Henry
I'm sure it can be done, and maybe has, but ... Feb 11 2016, 10:35 PM
jd74914
I am modeling the Type 4 based upon other engines... Feb 12 2016, 10:27 AM
jmill IMHO twin plugging and race gas are exotic extreme... Feb 11 2016, 07:12 PM
ConeDodger
[quote name='ConeDodger' post='2301947' date='Feb... Feb 12 2016, 12:17 AM
Mueller The cooling, or lack of is why such low compressio... Feb 11 2016, 10:07 PM
Beebo Kanelle Thank you all for all your input. I knew that the... Feb 11 2016, 11:04 PM
stugray
So to sum up, the enemy that needs to be addresse... Feb 11 2016, 11:53 PM
Mark Henry
So to sum up, the enemy that needs to be address... Feb 12 2016, 03:07 AM
Steve Pratel Eh, I'm not buying it.
Driveable? Porsche sol... Feb 12 2016, 10:33 AM
McMark If you're looking to improve thermodynamic eff... Feb 12 2016, 09:50 AM
Mark Henry
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:21 AM
jd74914
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:25 AM
ra272
If you're looking to improve thermodynamic ef... Feb 15 2016, 03:36 PM
Mark Henry
If you're looking to improve thermodynamic e... Feb 15 2016, 03:54 PM
Beebo Kanelle guys! I didn't mean to start a firestorm ... Feb 12 2016, 12:12 PM
Mark Henry
guys! I didn't mean to start a firestorm... Feb 12 2016, 01:40 PM
jd74914
guys! I didn't mean to start a firestorm... Feb 12 2016, 03:50 PM
Mueller You really cannot model the Type IV using past mot... Feb 12 2016, 12:16 PM
Beebo Kanelle probably not, it may all blow up - but I do want t... Feb 12 2016, 12:24 PM
Beebo Kanelle and, if it all blows up, Y'all will be among t... Feb 12 2016, 12:29 PM
brant seriously.... as a hypothetical discussion you can... Feb 12 2016, 02:30 PM
r_towle I would suggest you call around, talk with JAke Ra... Feb 12 2016, 03:23 PM
HAM Inc If your goal is 100hp/liter T4 you're best cha... Feb 12 2016, 04:17 PM
veekry9 zcPGfjUO3Yg
https://www.youtube.com/user/Grasshut... Feb 12 2016, 07:19 PM
Mark Henry
The 380hp corvair engine, with the coin in it you... Feb 12 2016, 09:32 PM
r_towle I admire what you are doing, and that you can do i... Feb 12 2016, 09:39 PM
Beebo Kanelle wow! Thanks to all for all the input.
to an... Feb 12 2016, 10:00 PM
Mark Henry
to a... Feb 13 2016, 10:56 AM
DBCooper
[b]In VW beetles, T4 upright fan conversions the ... Feb 13 2016, 12:20 PM
Mark Henry
[quote name='Mark Henry' post='2302557' date='Feb... Feb 13 2016, 12:47 PM
r_towle Look at how the 911 turbo seals the head to cylind... Feb 12 2016, 10:18 PM
Mark Henry
Look at how the 911 turbo seals the head to cylin... Feb 13 2016, 11:55 AM
colingreene Is this thread still going? I lost interest in try... Feb 13 2016, 11:46 AM
stugray It might have been lost in the thread:
If you wan... Feb 13 2016, 12:32 PM
DBCooper Yup, original OPP with Joe's handwritten instr... Feb 13 2016, 04:08 PM
Mark Henry
Yup, original OPP with Joe's handwritten inst... Feb 13 2016, 04:35 PM
DBCooper
Yup, original OPP with Joe's handwritten ins... Feb 13 2016, 05:01 PM
veekry9 vmkKqVc2g0s
http://www.forestcitycastings.com/serv... Feb 14 2016, 05:14 AM
Mueller
Design brief:
1) air/liquid cooled hybrid
2) ... Feb 14 2016, 03:30 PM
Mark Henry
Maybe I missed it, but I didn't see him pos... Feb 14 2016, 04:20 PM
veekry9 http://www.amazon.ca/Air-Cooled-Motor-Engi...%2C+L... Feb 14 2016, 08:32 AM
Mark Henry OK then....enough of the yakety yack...Build it... Feb 14 2016, 09:38 AM
veekry9 https://www.google.ca/webhp?sourceid=chrome...mpos... Feb 14 2016, 11:01 AM
Beebo Kanelle Thanks Veekry9! Found a 2nd edition (1972) o... Feb 14 2016, 11:14 AM
Mark Henry
Thanks Veekry9! Found a 2nd edition (1972) ... Feb 14 2016, 01:01 PM
Beebo Kanelle Thank you, Mueller -
I just have some ideas that ... Feb 14 2016, 04:10 PM
veekry9 That's the beauty of the freedom of free will,... Feb 15 2016, 12:27 AM
Mark Henry
That's the beauty of the freedom of free will... Feb 15 2016, 08:44 AM
Beebo Kanelle Its getting done...
maybe not on a Canadian sch... Feb 15 2016, 09:35 AM
Steve Pratel :popcorn: Feb 15 2016, 02:53 PM
cgnj Please let this thread die Feb 15 2016, 03:20 PM
914_teener
:popcorn:
:bullshit: :idea: :toke: :sleep: Feb 15 2016, 03:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th June 2026 - 08:40 AM |
