| Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
| Beebo Kanelle |
Feb 12 2016, 12:12 PM
guys! I didn't mean to start a firestorm over this... I was just curious as to what the mechanical limitations of the type 4 engine was
no secrets here. as for the concept, its a variation of the Atkinson / Miller cycle. On circular intake ports it seems to be possible to minimize the pumping losses while taking advantage of a much greater expansion cycle. for example, instead of 1-2 pts, utilize 5-7 pts, allowing for a cooler exhaust and broadening the torque curve. Years ago I took my Audi 5000 turbo and increased to CR to 11:8 +- while altering the cam timing events so the actual CR was 8:1 - that is my reference point - variations on this theme have been done to jaguar engines and a domestic v8 - all liquid cooled I bought a 914 when I started having more time, and have become intrigued with the Type 4 engine. as far as the modeling, right now its computer - and I'll see where that leads me. |
| Mark Henry |
Feb 12 2016, 01:40 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
guys! I didn't mean to start a firestorm over this... I was just curious as to what the mechanical limitations of the type 4 engine was no secrets here. as for the concept, its a variation of the Atkinson / Miller cycle. On circular intake ports it seems to be possible to minimize the pumping losses while taking advantage of a much greater expansion cycle. for example, instead of 1-2 pts, utilize 5-7 pts, allowing for a cooler exhaust and broadening the torque curve. Years ago I took my Audi 5000 turbo and increased to CR to 11:8 +- while altering the cam timing events so the actual CR was 8:1 - that is my reference point - variations on this theme have been done to jaguar engines and a domestic v8 - all liquid cooled I bought a 914 when I started having more time, and have become intrigued with the Type 4 engine. as far as the modeling, right now its computer - and I'll see where that leads me. QUOTE as for the concept, its a variation of the Atkinson / Miller cycle. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) The type 4 engine is a 50 year old 2 valve pushrod design based on a 85 year old 2 valve pushrod design. Add to this that the Type 4 has weak head sealing/bolt design for turbo or supercharging at anything but moderate levels. The thing is unless you have made a amazing Type 4 flux capacitor breakthrough, what you are talking about would be better off started on a clean slate. There has been all kinds of theoretical engine discussion here over the years. Not once has anything come to fruition that hasn't been already been firmly rooted in current or past technology. Computer modeling can be great, but the Type 4 is oldschool, try building a couple of real T4 engines first. Then get back to us with some theories. PM member veekry9, he would be a perfect muse, who knows maybe the two of you can make an amazing breakthrough. (IMG:style_emoticons/default/smile.gif) |
Beebo Kanelle Type 4 mechanical compression ratio Feb 11 2016, 01:03 PM
914_teener
OK, here's a fun one for the novice to ponder... Feb 11 2016, 01:27 PM
Mark Henry Kind of funny way of asking what is the max HP a T... Feb 11 2016, 02:19 PM
colingreene Compression ratio is often set by quality of fuel.... Feb 11 2016, 02:22 PM
Dave_Darling Assuming you aren't actually trying to burn an... Feb 11 2016, 04:10 PM
r_towle 13:1 at 200 hp
Race fuel only.
Could not move the... Feb 11 2016, 04:14 PM
Beebo Kanelle Thank you one and all.
I'm afraid I wasn... Feb 11 2016, 04:35 PM
Steve Pratel
I'm afraid I wasn... Feb 11 2016, 10:11 PM
Mark Henry
I'm sure it can be done, and maybe has, but ... Feb 11 2016, 10:35 PM
jd74914
I am modeling the Type 4 based upon other engines... Feb 12 2016, 10:27 AM
jmill IMHO twin plugging and race gas are exotic extreme... Feb 11 2016, 07:12 PM
brant The materials used in a stock 914 engine do not li... Feb 11 2016, 07:39 PM
ConeDodger
The materials used in a stock 914 engine do not l... Feb 11 2016, 09:06 PM
Mark Henry
The materials used in a stock 914 engine do not ... Feb 11 2016, 09:20 PM
ConeDodger
[quote name='ConeDodger' post='2301947' date='Feb... Feb 12 2016, 12:17 AM
Mueller The cooling, or lack of is why such low compressio... Feb 11 2016, 10:07 PM
Beebo Kanelle Thank you all for all your input. I knew that the... Feb 11 2016, 11:04 PM
stugray
So to sum up, the enemy that needs to be addresse... Feb 11 2016, 11:53 PM
Mark Henry
So to sum up, the enemy that needs to be address... Feb 12 2016, 03:07 AM
Steve Pratel Eh, I'm not buying it.
Driveable? Porsche sol... Feb 12 2016, 10:33 AM
McMark If you're looking to improve thermodynamic eff... Feb 12 2016, 09:50 AM
Mark Henry
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:21 AM
jd74914
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:25 AM
ra272
If you're looking to improve thermodynamic ef... Feb 15 2016, 03:36 PM
Mark Henry
If you're looking to improve thermodynamic e... Feb 15 2016, 03:54 PM
jd74914
guys! I didn't mean to start a firestorm... Feb 12 2016, 03:50 PM
Mueller You really cannot model the Type IV using past mot... Feb 12 2016, 12:16 PM
Beebo Kanelle probably not, it may all blow up - but I do want t... Feb 12 2016, 12:24 PM
Beebo Kanelle and, if it all blows up, Y'all will be among t... Feb 12 2016, 12:29 PM
brant seriously.... as a hypothetical discussion you can... Feb 12 2016, 02:30 PM
r_towle I would suggest you call around, talk with JAke Ra... Feb 12 2016, 03:23 PM
HAM Inc If your goal is 100hp/liter T4 you're best cha... Feb 12 2016, 04:17 PM
veekry9 zcPGfjUO3Yg
https://www.youtube.com/user/Grasshut... Feb 12 2016, 07:19 PM
Mark Henry
The 380hp corvair engine, with the coin in it you... Feb 12 2016, 09:32 PM
r_towle I admire what you are doing, and that you can do i... Feb 12 2016, 09:39 PM
Beebo Kanelle wow! Thanks to all for all the input.
to an... Feb 12 2016, 10:00 PM
Mark Henry
to a... Feb 13 2016, 10:56 AM
DBCooper
[b]In VW beetles, T4 upright fan conversions the ... Feb 13 2016, 12:20 PM
Mark Henry
[quote name='Mark Henry' post='2302557' date='Feb... Feb 13 2016, 12:47 PM
r_towle Look at how the 911 turbo seals the head to cylind... Feb 12 2016, 10:18 PM
Mark Henry
Look at how the 911 turbo seals the head to cylin... Feb 13 2016, 11:55 AM
colingreene Is this thread still going? I lost interest in try... Feb 13 2016, 11:46 AM
stugray It might have been lost in the thread:
If you wan... Feb 13 2016, 12:32 PM
DBCooper Yup, original OPP with Joe's handwritten instr... Feb 13 2016, 04:08 PM
Mark Henry
Yup, original OPP with Joe's handwritten inst... Feb 13 2016, 04:35 PM
DBCooper
Yup, original OPP with Joe's handwritten ins... Feb 13 2016, 05:01 PM
veekry9 vmkKqVc2g0s
http://www.forestcitycastings.com/serv... Feb 14 2016, 05:14 AM
Mueller
Design brief:
1) air/liquid cooled hybrid
2) ... Feb 14 2016, 03:30 PM
Mark Henry
Maybe I missed it, but I didn't see him pos... Feb 14 2016, 04:20 PM
veekry9 http://www.amazon.ca/Air-Cooled-Motor-Engi...%2C+L... Feb 14 2016, 08:32 AM
Mark Henry OK then....enough of the yakety yack...Build it... Feb 14 2016, 09:38 AM
veekry9 https://www.google.ca/webhp?sourceid=chrome...mpos... Feb 14 2016, 11:01 AM
Beebo Kanelle Thanks Veekry9! Found a 2nd edition (1972) o... Feb 14 2016, 11:14 AM
Mark Henry
Thanks Veekry9! Found a 2nd edition (1972) ... Feb 14 2016, 01:01 PM
Beebo Kanelle Thank you, Mueller -
I just have some ideas that ... Feb 14 2016, 04:10 PM
veekry9 That's the beauty of the freedom of free will,... Feb 15 2016, 12:27 AM
Mark Henry
That's the beauty of the freedom of free will... Feb 15 2016, 08:44 AM
Beebo Kanelle Its getting done...
maybe not on a Canadian sch... Feb 15 2016, 09:35 AM
Steve Pratel :popcorn: Feb 15 2016, 02:53 PM
cgnj Please let this thread die Feb 15 2016, 03:20 PM
914_teener
:popcorn:
:bullshit: :idea: :toke: :sleep: Feb 15 2016, 03:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th June 2026 - 09:51 AM |
