> Type 4 mechanical compression ratio, Why is the factory compression so low?
Beebo Kanelle
post Feb 11 2016, 01:03 PM
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low?
and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations -
I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology.
Thanks
veekry9
post Feb 12 2016, 07:19 PM
OldMember
Group: Retired Members
https://www.youtube.com/watch?v=zcPGfjUO3Yg
https://www.youtube.com/user/GrasshutPerformance/discussion
https://en.wikipedia.org/wiki/Julius_Mackerle
Turbo,efi,titanium weight-loss,auxiliary head and piston cooling,21st century sensors.
The heads lifting off will need a cure,like o-ringing them on to the nickies,stiffening the heads.
Note the use of modern off the shelf rods,as an economy.( Honda B16A H beam con rods)
Maximum effort calls for maximum control of heat in fine resolution.
An aluminum liquid coolant tube inserted into the head to sink heat will work too.
Not quite HD,but a bridgeport mill op,to keep a cool head.
The use of modern coatings to reduce friction and conduction is effective.
There,I spent some money for you,as any thing is possible.Methanol/Nitro fuel engine?
CadCam a set of new three valve heads you can graphite diecast for cheap and have a prototype shop do a short run on speculation.
I'll give you their number:
http://www.armstrongmold.com/pages/graphite_die_casting.html
(IMG:style_emoticons/default/happy11.gif)
Reading,it's good fer yuh.
Julius Mackerle: Air-Cooled Motor Engines, Cleaver-Hume Press, London 1961
Julius Mackerle: Air-Cooled Automobile Engines, The Institute of Mechanical Engineers, London 1961-2
Mark Henry
post Feb 12 2016, 09:32 PM
that's what I do!
QUOTE(veekry9 @ Feb 12 2016, 08:19 PM) *
The 380hp corvair engine, with the coin in it you likely can do a /6 turbo engine
Well not what I'd call 21 century
The heads and sealing is't the big issue it's the two different lengths of the head studs. It's not O-rings it is fire rings, a solid steel ring precision matched machined into the head and cylinder. Old 911 turbo technology
That's a given if using a stroked crank
I use dry film, ceramic piston ton top coatings, etc.
Ok for a dragster...but street?
I'm not trying to be a smart ass here, but there is nothing new or innovative in any of this stuff.
Now the last comment on three valve heads, we've been hearing about 4 valve per cylinder heads since the early 2000, we're still waiting....
But even they do get made my bet is they will be nothing but a novelty due to price.
Beebo Kanelle   Type 4 mechanical compression ratio   Feb 11 2016, 01:03 PM
914_teener   OK, here's a fun one for the novice to ponder...   Feb 11 2016, 01:27 PM
Mark Henry   Kind of funny way of asking what is the max HP a T...   Feb 11 2016, 02:19 PM
colingreene   Compression ratio is often set by quality of fuel....   Feb 11 2016, 02:22 PM
Dave_Darling   Assuming you aren't actually trying to burn an...   Feb 11 2016, 04:10 PM
r_towle   13:1 at 200 hp Race fuel only. Could not move the...   Feb 11 2016, 04:14 PM
Beebo Kanelle   Thank you one and all. I'm afraid I wasn...   Feb 11 2016, 04:35 PM
Steve Pratel   Thank you one and all. I'm afraid I wasn...   Feb 11 2016, 10:11 PM
Mark Henry   I'm sure it can be done, and maybe has, but ...   Feb 11 2016, 10:35 PM
jd74914   I am modeling the Type 4 based upon other engines...   Feb 12 2016, 10:27 AM
jmill   IMHO twin plugging and race gas are exotic extreme...   Feb 11 2016, 07:12 PM
brant   The materials used in a stock 914 engine do not li...   Feb 11 2016, 07:39 PM
ConeDodger   The materials used in a stock 914 engine do not l...   Feb 11 2016, 09:06 PM
Mark Henry   The materials used in a stock 914 engine do not ...   Feb 11 2016, 09:20 PM
ConeDodger   [quote name='ConeDodger' post='2301947' date='Feb...   Feb 12 2016, 12:17 AM
Mueller   The cooling, or lack of is why such low compressio...   Feb 11 2016, 10:07 PM
Beebo Kanelle   Thank you all for all your input. I knew that the...   Feb 11 2016, 11:04 PM
stugray   So to sum up, the enemy that needs to be addresse...   Feb 11 2016, 11:53 PM
Mark Henry   So to sum up, the enemy that needs to be address...   Feb 12 2016, 03:07 AM
Steve Pratel   Eh, I'm not buying it. Driveable? Porsche sol...   Feb 12 2016, 10:33 AM
McMark   If you're looking to improve thermodynamic eff...   Feb 12 2016, 09:50 AM
Mark Henry   If you're looking to improve thermodynamic ef...   Feb 12 2016, 10:21 AM
jd74914   If you're looking to improve thermodynamic ef...   Feb 12 2016, 10:25 AM
ra272   If you're looking to improve thermodynamic ef...   Feb 15 2016, 03:36 PM
Mark Henry   If you're looking to improve thermodynamic e...   Feb 15 2016, 03:54 PM
Beebo Kanelle   guys! I didn't mean to start a firestorm ...   Feb 12 2016, 12:12 PM
Mark Henry   guys! I didn't mean to start a firestorm...   Feb 12 2016, 01:40 PM
jd74914   guys! I didn't mean to start a firestorm...   Feb 12 2016, 03:50 PM
Mueller   You really cannot model the Type IV using past mot...   Feb 12 2016, 12:16 PM
Beebo Kanelle   probably not, it may all blow up - but I do want t...   Feb 12 2016, 12:24 PM
Beebo Kanelle   and, if it all blows up, Y'all will be among t...   Feb 12 2016, 12:29 PM
brant   seriously.... as a hypothetical discussion you can...   Feb 12 2016, 02:30 PM
r_towle   I would suggest you call around, talk with JAke Ra...   Feb 12 2016, 03:23 PM
HAM Inc   If your goal is 100hp/liter T4 you're best cha...   Feb 12 2016, 04:17 PM
veekry9   zcPGfjUO3Yg https://www.youtube.com/user/Grasshut...   Feb 12 2016, 07:19 PM
Mark Henry   The 380hp corvair engine, with the coin in it you...   Feb 12 2016, 09:32 PM
r_towle   I admire what you are doing, and that you can do i...   Feb 12 2016, 09:39 PM
Beebo Kanelle   wow! Thanks to all for all the input. to an...   Feb 12 2016, 10:00 PM
Mark Henry   wow! Thanks to all for all the input. to a...   Feb 13 2016, 10:56 AM
DBCooper   [b]In VW beetles, T4 upright fan conversions the ...   Feb 13 2016, 12:20 PM
Mark Henry   [quote name='Mark Henry' post='2302557' date='Feb...   Feb 13 2016, 12:47 PM
r_towle   Look at how the 911 turbo seals the head to cylind...   Feb 12 2016, 10:18 PM
Mark Henry   Look at how the 911 turbo seals the head to cylin...   Feb 13 2016, 11:55 AM
colingreene   Is this thread still going? I lost interest in try...   Feb 13 2016, 11:46 AM
stugray   It might have been lost in the thread: If you wan...   Feb 13 2016, 12:32 PM
DBCooper   Yup, original OPP with Joe's handwritten instr...   Feb 13 2016, 04:08 PM
Mark Henry   Yup, original OPP with Joe's handwritten inst...   Feb 13 2016, 04:35 PM
DBCooper   Yup, original OPP with Joe's handwritten ins...   Feb 13 2016, 05:01 PM
veekry9   vmkKqVc2g0s http://www.forestcitycastings.com/serv...   Feb 14 2016, 05:14 AM
Mueller   Design brief: 1) air/liquid cooled hybrid 2) ...   Feb 14 2016, 03:30 PM
Mark Henry   Maybe I missed it, but I didn't see him pos...   Feb 14 2016, 04:20 PM
veekry9   http://www.amazon.ca/Air-Cooled-Motor-Engi...%2C+L...   Feb 14 2016, 08:32 AM
Mark Henry   OK then....enough of the yakety yack...Build it...   Feb 14 2016, 09:38 AM
veekry9   https://www.google.ca/webhp?sourceid=chrome...mpos...   Feb 14 2016, 11:01 AM
Beebo Kanelle   Thanks Veekry9! Found a 2nd edition (1972) o...   Feb 14 2016, 11:14 AM
Mark Henry   Thanks Veekry9! Found a 2nd edition (1972) ...   Feb 14 2016, 01:01 PM
Beebo Kanelle   Thank you, Mueller - I just have some ideas that ...   Feb 14 2016, 04:10 PM
veekry9   That's the beauty of the freedom of free will,...   Feb 15 2016, 12:27 AM
Mark Henry   That's the beauty of the freedom of free will...   Feb 15 2016, 08:44 AM
Beebo Kanelle   Its getting done... maybe not on a Canadian sch...   Feb 15 2016, 09:35 AM
Steve Pratel   :popcorn:   Feb 15 2016, 02:53 PM
cgnj   Please let this thread die   Feb 15 2016, 03:20 PM
914_teener   :popcorn: :bullshit: :idea: :toke: :sleep:   Feb 15 2016, 03:21 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th June 2026 - 09:50 AM
