> Type 4 mechanical compression ratio, Why is the factory compression so low?
Beebo Kanelle
post Feb 11 2016, 01:03 PM
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low?
and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations -
I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology.
Thanks
r_towle
post Feb 12 2016, 10:18 PM
Custom Member
Look at how the 911 turbo seals the head to cylinder.
Basically a small diameter wire machined into the head and cylinder, then crushed when torqued down.
Mark Henry
post Feb 13 2016, 11:55 AM
that's what I do!
QUOTE(r_towle @ Feb 12 2016, 11:18 PM) *
No Rich, you don't understand what I mean by fire ring .
The Fire ring that is match machined into a high performance 911 turbo head and cylinder. The ring also stops cylinder head movement or shuffle.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-26-1455386123.1.jpg)
BTW I often work on a 500+hp porsche 911 turbo 3.8L high performance engine that has over 100hp/cyl.
The owner has well over $80K into the engine alone...this time around.
Beebo Kanelle   Type 4 mechanical compression ratio   Feb 11 2016, 01:03 PM
914_teener   OK, here's a fun one for the novice to ponder...   Feb 11 2016, 01:27 PM
Mark Henry   Kind of funny way of asking what is the max HP a T...   Feb 11 2016, 02:19 PM
colingreene   Compression ratio is often set by quality of fuel....   Feb 11 2016, 02:22 PM
Dave_Darling   Assuming you aren't actually trying to burn an...   Feb 11 2016, 04:10 PM
r_towle   13:1 at 200 hp Race fuel only. Could not move the...   Feb 11 2016, 04:14 PM
Beebo Kanelle   Thank you one and all. I'm afraid I wasn...   Feb 11 2016, 04:35 PM
Steve Pratel   Thank you one and all. I'm afraid I wasn...   Feb 11 2016, 10:11 PM
Mark Henry   I'm sure it can be done, and maybe has, but ...   Feb 11 2016, 10:35 PM
jd74914   I am modeling the Type 4 based upon other engines...   Feb 12 2016, 10:27 AM
jmill   IMHO twin plugging and race gas are exotic extreme...   Feb 11 2016, 07:12 PM
brant   The materials used in a stock 914 engine do not li...   Feb 11 2016, 07:39 PM
ConeDodger   The materials used in a stock 914 engine do not l...   Feb 11 2016, 09:06 PM
Mark Henry   The materials used in a stock 914 engine do not ...   Feb 11 2016, 09:20 PM
ConeDodger   [quote name='ConeDodger' post='2301947' date='Feb...   Feb 12 2016, 12:17 AM
Mueller   The cooling, or lack of is why such low compressio...   Feb 11 2016, 10:07 PM
Beebo Kanelle   Thank you all for all your input. I knew that the...   Feb 11 2016, 11:04 PM
stugray   So to sum up, the enemy that needs to be addresse...   Feb 11 2016, 11:53 PM
Mark Henry   So to sum up, the enemy that needs to be address...   Feb 12 2016, 03:07 AM
Steve Pratel   Eh, I'm not buying it. Driveable? Porsche sol...   Feb 12 2016, 10:33 AM
McMark   If you're looking to improve thermodynamic eff...   Feb 12 2016, 09:50 AM
Mark Henry   If you're looking to improve thermodynamic ef...   Feb 12 2016, 10:21 AM
jd74914   If you're looking to improve thermodynamic ef...   Feb 12 2016, 10:25 AM
ra272   If you're looking to improve thermodynamic ef...   Feb 15 2016, 03:36 PM
Mark Henry   If you're looking to improve thermodynamic e...   Feb 15 2016, 03:54 PM
Beebo Kanelle   guys! I didn't mean to start a firestorm ...   Feb 12 2016, 12:12 PM
Mark Henry   guys! I didn't mean to start a firestorm...   Feb 12 2016, 01:40 PM
jd74914   guys! I didn't mean to start a firestorm...   Feb 12 2016, 03:50 PM
Mueller   You really cannot model the Type IV using past mot...   Feb 12 2016, 12:16 PM
Beebo Kanelle   probably not, it may all blow up - but I do want t...   Feb 12 2016, 12:24 PM
Beebo Kanelle   and, if it all blows up, Y'all will be among t...   Feb 12 2016, 12:29 PM
brant   seriously.... as a hypothetical discussion you can...   Feb 12 2016, 02:30 PM
r_towle   I would suggest you call around, talk with JAke Ra...   Feb 12 2016, 03:23 PM
HAM Inc   If your goal is 100hp/liter T4 you're best cha...   Feb 12 2016, 04:17 PM
veekry9   zcPGfjUO3Yg https://www.youtube.com/user/Grasshut...   Feb 12 2016, 07:19 PM
Mark Henry   The 380hp corvair engine, with the coin in it you...   Feb 12 2016, 09:32 PM
r_towle   I admire what you are doing, and that you can do i...   Feb 12 2016, 09:39 PM
Beebo Kanelle   wow! Thanks to all for all the input. to an...   Feb 12 2016, 10:00 PM
Mark Henry   wow! Thanks to all for all the input. to a...   Feb 13 2016, 10:56 AM
DBCooper   [b]In VW beetles, T4 upright fan conversions the ...   Feb 13 2016, 12:20 PM
Mark Henry   [quote name='Mark Henry' post='2302557' date='Feb...   Feb 13 2016, 12:47 PM
r_towle   Look at how the 911 turbo seals the head to cylind...   Feb 12 2016, 10:18 PM
Mark Henry   Look at how the 911 turbo seals the head to cylin...   Feb 13 2016, 11:55 AM
colingreene   Is this thread still going? I lost interest in try...   Feb 13 2016, 11:46 AM
stugray   It might have been lost in the thread: If you wan...   Feb 13 2016, 12:32 PM
DBCooper   Yup, original OPP with Joe's handwritten instr...   Feb 13 2016, 04:08 PM
Mark Henry   Yup, original OPP with Joe's handwritten inst...   Feb 13 2016, 04:35 PM
DBCooper   Yup, original OPP with Joe's handwritten ins...   Feb 13 2016, 05:01 PM
veekry9   vmkKqVc2g0s http://www.forestcitycastings.com/serv...   Feb 14 2016, 05:14 AM
Mueller   Design brief: 1) air/liquid cooled hybrid 2) ...   Feb 14 2016, 03:30 PM
Mark Henry   Maybe I missed it, but I didn't see him pos...   Feb 14 2016, 04:20 PM
veekry9   http://www.amazon.ca/Air-Cooled-Motor-Engi...%2C+L...   Feb 14 2016, 08:32 AM
Mark Henry   OK then....enough of the yakety yack...Build it...   Feb 14 2016, 09:38 AM
veekry9   https://www.google.ca/webhp?sourceid=chrome...mpos...   Feb 14 2016, 11:01 AM
Beebo Kanelle   Thanks Veekry9! Found a 2nd edition (1972) o...   Feb 14 2016, 11:14 AM
Mark Henry   Thanks Veekry9! Found a 2nd edition (1972) ...   Feb 14 2016, 01:01 PM
Beebo Kanelle   Thank you, Mueller - I just have some ideas that ...   Feb 14 2016, 04:10 PM
veekry9   That's the beauty of the freedom of free will,...   Feb 15 2016, 12:27 AM
Mark Henry   That's the beauty of the freedom of free will...   Feb 15 2016, 08:44 AM
Beebo Kanelle   Its getting done... maybe not on a Canadian sch...   Feb 15 2016, 09:35 AM
Steve Pratel   :popcorn:   Feb 15 2016, 02:53 PM
cgnj   Please let this thread die   Feb 15 2016, 03:20 PM
914_teener   :popcorn: :bullshit: :idea: :toke: :sleep:   Feb 15 2016, 03:21 PM
- Lo-Fi Version Time is now: 18th June 2026 - 08:41 AM
