| Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
| Beebo Kanelle |
Feb 12 2016, 10:00 PM
wow! Thanks to all for all the input.
to answer jd74914 questions: 1) initially, I just use a spiral notebook and a pen to gather info, 2) initial dynamic modeling using 'Dynomation", 3) take the data and build one... see how long it takes to blow up! The #1 concern that pops up from the comments, after 'it can't be done', is the cylinder/head sealing - I can only assume that the Type 4 engine 'flops' around - and what about stability and flex of the crank? That would necessitate small bore to minimize flex. But please tell me, is the head/cylinder just a registered fit under compression? As far as air-cooling goes, does anything compare to Mr. Raby's DTM system used in conjunction with Nikasil? Is there a book or source with all the torques, tolerances and dimensions? I know that after 40 years, there must be a lot of hard data, somewhere. Thanks again |
| Mark Henry |
Feb 13 2016, 10:56 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
wow! Thanks to all for all the input. to answer jd74914 questions: 1) initially, I just use a spiral notebook and a pen to gather info, 2) initial dynamic modeling using 'Dynomation", 3) take the data and build one... see how long it takes to blow up! The #1 concern that pops up from the comments, after 'it can't be done', is the cylinder/head sealing - I can only assume that the Type 4 engine 'flops' around - and what about stability and flex of the crank? Crank has two throws per main journal thus is has RPM limitations. You can't reduce rod journal size for different rod (ie rabbit rods) already been done, too much flex. Cylinder head bolt pattern is too big, upper studs shorter than lowers, fire rings have been tried, 5th head stud has been tried.... Never said "it can't be done", just said the T4 design has it's limitations and that conventionally in most cases it will have already been tried or done. You have to keep in mind guys have been hopping these things up since the 70's and for the type 1 since the 50's. Many also have proven track records , proven engine building creds and/or or proven products lines. We are talking real stuff not just theories. That would necessitate small bore to minimize flex. But please tell me, is the head/cylinder just a registered fit under compression? It sits in a bore As far as air-cooling goes, does anything compare to Mr. Raby's DTM system used in conjunction with Nikasil? In a 914 I still say the DTM is a waste of money, the exception would be a full race car with the shrouding cut away. In VW beetles, T4 upright fan conversions the DTM is the snizzle. I built a DTM/Joe Cali/Stock T1 hybrid shroud for my '67 bug, it came out great, but in retrospect the amount of time spent on it I wish I has just bought a DTM. A DTM can be installed in a day. Is there a book or source with all the torques, tolerances and dimensions? I know that after 40 years, there must be a lot of hard data, somewhere. Bentley manual (IMG:style_emoticons/default/confused24.gif) Even performance most of that stuff is still the same as stock. The stuff that changes for performance is mostly just dimensions. Thanks again |
| DBCooper |
Feb 13 2016, 12:20 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
[b]In VW beetles, T4 upright fan conversions the DTM is the snizzle. I built a DTM/Joe Cali/Stock T1 hybrid shroud for my '67 bug, it came out great, but in retrospect the amount of time spent on it I wish I has just bought a DTM. You built a Cali shroud? From the time of the Usenet RAMVA groups? Man, you HAVE been around for a while, so hat's off to you. I still have an unused original Joe Locicero DTM kit in a box somewhere, before Jake took over, with Joe's own handwritten instructions. Good man. |
| Mark Henry |
Feb 13 2016, 12:47 PM
[b]In VW beetles, T4 upright fan conversions the DTM is the snizzle. I built a DTM/Joe Cali/Stock T1 hybrid shroud for my '67 bug, it came out great, but in retrospect the amount of time spent on it I wish I has just bought a DTM. You built a Cali shroud? From the time of the Usenet RAMVA groups? Man, you HAVE been around for a while, so hat's off to you. I still have an unused original Joe Locicero DTM kit in a box somewhere, before Jake took over, with Joe's own handwritten instructions. Good man. That original DTM by Joe would an OPP (Oregon Performance products). I've also used FAT and Sharpbuilt shrouds in the past. My all steel shroud. (IMG:http://www.914world.com/bbs2/uploads/post-73-1403365366.jpg) |
Beebo Kanelle Type 4 mechanical compression ratio Feb 11 2016, 01:03 PM
914_teener
OK, here's a fun one for the novice to ponder... Feb 11 2016, 01:27 PM
Mark Henry Kind of funny way of asking what is the max HP a T... Feb 11 2016, 02:19 PM
colingreene Compression ratio is often set by quality of fuel.... Feb 11 2016, 02:22 PM
Dave_Darling Assuming you aren't actually trying to burn an... Feb 11 2016, 04:10 PM
r_towle 13:1 at 200 hp
Race fuel only.
Could not move the... Feb 11 2016, 04:14 PM
Beebo Kanelle Thank you one and all.
I'm afraid I wasn... Feb 11 2016, 04:35 PM
Steve Pratel
I'm afraid I wasn... Feb 11 2016, 10:11 PM
Mark Henry
I'm sure it can be done, and maybe has, but ... Feb 11 2016, 10:35 PM
jd74914
I am modeling the Type 4 based upon other engines... Feb 12 2016, 10:27 AM
jmill IMHO twin plugging and race gas are exotic extreme... Feb 11 2016, 07:12 PM
brant The materials used in a stock 914 engine do not li... Feb 11 2016, 07:39 PM
ConeDodger
The materials used in a stock 914 engine do not l... Feb 11 2016, 09:06 PM
Mark Henry
The materials used in a stock 914 engine do not ... Feb 11 2016, 09:20 PM
ConeDodger
[quote name='ConeDodger' post='2301947' date='Feb... Feb 12 2016, 12:17 AM
Mueller The cooling, or lack of is why such low compressio... Feb 11 2016, 10:07 PM
Beebo Kanelle Thank you all for all your input. I knew that the... Feb 11 2016, 11:04 PM
stugray
So to sum up, the enemy that needs to be addresse... Feb 11 2016, 11:53 PM
Mark Henry
So to sum up, the enemy that needs to be address... Feb 12 2016, 03:07 AM
Steve Pratel Eh, I'm not buying it.
Driveable? Porsche sol... Feb 12 2016, 10:33 AM
McMark If you're looking to improve thermodynamic eff... Feb 12 2016, 09:50 AM
Mark Henry
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:21 AM
jd74914
If you're looking to improve thermodynamic ef... Feb 12 2016, 10:25 AM
ra272
If you're looking to improve thermodynamic ef... Feb 15 2016, 03:36 PM
Mark Henry
If you're looking to improve thermodynamic e... Feb 15 2016, 03:54 PM
Beebo Kanelle guys! I didn't mean to start a firestorm ... Feb 12 2016, 12:12 PM
Mark Henry
guys! I didn't mean to start a firestorm... Feb 12 2016, 01:40 PM
jd74914
guys! I didn't mean to start a firestorm... Feb 12 2016, 03:50 PM
Mueller You really cannot model the Type IV using past mot... Feb 12 2016, 12:16 PM
Beebo Kanelle probably not, it may all blow up - but I do want t... Feb 12 2016, 12:24 PM
Beebo Kanelle and, if it all blows up, Y'all will be among t... Feb 12 2016, 12:29 PM
brant seriously.... as a hypothetical discussion you can... Feb 12 2016, 02:30 PM
r_towle I would suggest you call around, talk with JAke Ra... Feb 12 2016, 03:23 PM
HAM Inc If your goal is 100hp/liter T4 you're best cha... Feb 12 2016, 04:17 PM
veekry9 zcPGfjUO3Yg
https://www.youtube.com/user/Grasshut... Feb 12 2016, 07:19 PM
Mark Henry
The 380hp corvair engine, with the coin in it you... Feb 12 2016, 09:32 PM
r_towle I admire what you are doing, and that you can do i... Feb 12 2016, 09:39 PM
r_towle Look at how the 911 turbo seals the head to cylind... Feb 12 2016, 10:18 PM
Mark Henry
Look at how the 911 turbo seals the head to cylin... Feb 13 2016, 11:55 AM
colingreene Is this thread still going? I lost interest in try... Feb 13 2016, 11:46 AM
stugray It might have been lost in the thread:
If you wan... Feb 13 2016, 12:32 PM
DBCooper Yup, original OPP with Joe's handwritten instr... Feb 13 2016, 04:08 PM
Mark Henry
Yup, original OPP with Joe's handwritten inst... Feb 13 2016, 04:35 PM
DBCooper
Yup, original OPP with Joe's handwritten ins... Feb 13 2016, 05:01 PM
veekry9 vmkKqVc2g0s
http://www.forestcitycastings.com/serv... Feb 14 2016, 05:14 AM
Mueller
Design brief:
1) air/liquid cooled hybrid
2) ... Feb 14 2016, 03:30 PM
Mark Henry
Maybe I missed it, but I didn't see him pos... Feb 14 2016, 04:20 PM
veekry9 http://www.amazon.ca/Air-Cooled-Motor-Engi...%2C+L... Feb 14 2016, 08:32 AM
Mark Henry OK then....enough of the yakety yack...Build it... Feb 14 2016, 09:38 AM
veekry9 https://www.google.ca/webhp?sourceid=chrome...mpos... Feb 14 2016, 11:01 AM
Beebo Kanelle Thanks Veekry9! Found a 2nd edition (1972) o... Feb 14 2016, 11:14 AM
Mark Henry
Thanks Veekry9! Found a 2nd edition (1972) ... Feb 14 2016, 01:01 PM
Beebo Kanelle Thank you, Mueller -
I just have some ideas that ... Feb 14 2016, 04:10 PM
veekry9 That's the beauty of the freedom of free will,... Feb 15 2016, 12:27 AM
Mark Henry
That's the beauty of the freedom of free will... Feb 15 2016, 08:44 AM
Beebo Kanelle Its getting done...
maybe not on a Canadian sch... Feb 15 2016, 09:35 AM
Steve Pratel :popcorn: Feb 15 2016, 02:53 PM
cgnj Please let this thread die Feb 15 2016, 03:20 PM
914_teener
:popcorn:
:bullshit: :idea: :toke: :sleep: Feb 15 2016, 03:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th June 2026 - 08:41 AM |
