> A Frayed Clutch Cable Screwed Up My Day
Larmo63
post Feb 13 2016, 05:58 PM
Right after I bought my latest '73 914, I went to adjust the clutch and I noticed the cable was a bit frayed. I ordered the stuff from Pelican, it's not here and I tempted fate. Well, it broke on the way home today from cars 'n coffee and it made for an interesting and frustrating afternoon. Of course, all the cable end parts are gone too, and I couldn't find anything in the street. More to order from Pelican.
Moral of the story: inspect your clutch cable routinely, and if it is AT ALL coming apart, it's GOING to break.
(IMG:style_emoticons/default/headbang.gif)
Dave_Darling
post Feb 13 2016, 09:52 PM
914 Idiot
Larmo, a couple of zip ties can hold the end of the cable onto the throwout arm. That should (in theory) keep it from going anywhere if the cable breaks.
Ndfrigi, your problem is in the ignition circuit, the tach going crazy indicates that. It may be as simple as the points getting unplugged! Time to check in your distributor. You can also unplug the tach signal wire (black/purple) from the coil's (-) terminal to see if there's a short there causing a lack of spark.
--DD
ndfrigi
post Feb 13 2016, 09:57 PM
QUOTE(Dave_Darling @ Feb 13 2016, 07:52 PM) *
--DD
Thank you too Dave!
Larmo63   A Frayed Clutch Cable Screwed Up My Day   Feb 13 2016, 05:58 PM
The Cabinetmaker   Happened more that once. Just drive it home with n...   Feb 13 2016, 06:25 PM
ndfrigi   I'm IN Lawrence! This morning heading ho...   Feb 13 2016, 06:39 PM
BeatNavy   Wow, it's a cars and coffee flatbed thread. B...   Feb 13 2016, 06:41 PM
r_towle   Thou shall never ignore a frayed clutch cable. Buy...   Feb 13 2016, 06:43 PM
Mikey914   Frayed clutch cable can be an indicator that the g...   Feb 13 2016, 07:25 PM
colingreene   Lawrence, I told you i have one at home. Noel your...   Feb 13 2016, 07:48 PM
ndfrigi   Lawrence, I told you i have one at home. Noel you...   Feb 13 2016, 09:55 PM
Dave_Darling   Larmo, a couple of zip ties can hold the end of th...   Feb 13 2016, 09:52 PM
ndfrigi   Larmo, a couple of zip ties can hold the end of t...   Feb 13 2016, 09:57 PM
rgalla9146   Larmo, a couple of zip ties can hold the end of t...   Feb 16 2016, 09:10 PM
914_teener   Larmo, a couple of zip ties can hold the end of ...   Feb 16 2016, 11:13 PM
Mikey914   [quote name='Dave_Darling' post='2302792' date='F...   Feb 17 2016, 10:29 AM
Tom_T   ndfrigi - they've got you covered on what to c...   Feb 14 2016, 12:51 AM
Larmo63   Mark and Tom, you're right!!! The...   Feb 14 2016, 07:54 PM
Mikey914   Top of the trans. To the body right above.   Feb 14 2016, 08:05 PM
Dave_Darling   There is a stud on the bottom of the rear trunk fl...   Feb 14 2016, 08:22 PM
Larmo63   Anybody have a decent spare transmission strap ava...   Feb 15 2016, 08:48 AM
jim_hoyland   A short battery ground cable will work; I may have...   Feb 15 2016, 09:01 AM
JRust   A short battery ground cable will work; I may hav...   Feb 15 2016, 09:17 AM
76-914   I've got one if your in need. Put your pic...   Feb 15 2016, 09:10 AM
Larmo63   I don't recall O' Reilly's having tha...   Feb 15 2016, 09:51 AM
Steve   I don't recall O' Reilly's having th...   Feb 15 2016, 11:49 AM
jimkelly   brilliant use of 6x6 es.   Feb 15 2016, 11:40 AM
mountainroads   Right after I bought my latest '73 914, I wen...   Feb 15 2016, 12:15 PM
ThePaintedMan   These are high quality and work GREAT. For the pri...   Feb 15 2016, 11:17 PM
colingreene   F'ing board software.   Feb 16 2016, 12:27 AM
colingreene   I've got one if your in need. Put your pic...   Feb 16 2016, 12:33 AM
Larmo63   What is the process for taking out the center cons...   Feb 16 2016, 04:48 PM
r_towle   Take off the face panel. Two screws up top to bott...   Feb 16 2016, 05:17 PM
Larmo63   Yeah, I got it out, I had never done it, pretty ea...   Feb 16 2016, 08:35 PM
r_towle   No pic, but go are far in as you can without restr...   Feb 16 2016, 08:43 PM
Larmo63   Threading the pedal end of the cable farther in. T...   Feb 16 2016, 09:55 PM
Dave_Darling   Haynes has a measurement for how far you thread th...   Feb 16 2016, 10:26 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 09:11 PM
