Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,219 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
OK, finally starting to put things back together. New bearings went into freshly powder coated trailing arms this evening.
I then went to install the new rubber bushings and pivot shaft from Elephant Racing and here is where I am running into problems even with their tool set. Per their instructions you set the bushings in the trailing arm and then using a pipe clamp and the provided tools, you soap the heck out of the parts and insert the pivot shaft through the one bushing and push it all the way through with pressure from the pipe clamp. Works well for the first few inches until the pivot shaft starts pulling the bushing down through the trailing arm. Getting everything back out was not fun, could only do it using my press. In watching a redneck video His description) the guy seems to put the pivot shaft on first and then push the bushings in at both ends. First seems to go easy, second he helps along with a hammer and a tool to fit over the bushing. Anyway, suggestions on best approach welcomed. I really figured that by paying a premium for the set with the tools that this would be simple. Arrrgh. Thanks, Mike |
Amphicar770 |
Yeah, this is really turning into a huge time waster and frustration maker. Just tried again with dry bushing into trailing arm, actually used motor oil to lube the shaft. Got it about half way and the pivot shaft again pulls in the bushing. The only way to then resolve is to put it in the press, push it back out, and start all over. If someone did not have a press I do not know how they could possibly reverse it.
If I can find my micrometer, I will compare thickness of pivot shaft to the original. I wonder if the new one is thicker? As I am apparently not the only one experiencing this problem, I have dropped a note to elephant to see what they might suggest. |
Lo-Fi Version | Time is now: 16th July 2025 - 04:17 PM |
