Under hard aceleration engine cuts out, Engine problems |
srozick |
Feb 20 2016, 04:40 PM
Newbie Group: Members Posts: 7 Joined: 11-October 15 From: Pittsburgh Member No.: 19,254 Region Association: None |
Hey, can you help.
We have a 73-914 1.7L. Under hard acceleration the engine cuts out and then we get a small back fire and the engine will catch. If we gradually accelerate the engine performs fine but is under hard acceleration that we have a problem. Can you possibly give us a direction to look to fix the problem. New fuel pump, new fuel filters,, and the tank was cleaned and lines flushed 200 miles ago. Thank for listening, |
mgphoto |
Feb 20 2016, 04:46 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hey, can you help. We have a 73-914 1.7L. Under hard acceleration the engine cuts out and then we get a small back fire and the engine will catch. If we gradually accelerate the engine performs fine but is under hard acceleration that we have a problem. Can you possibly give us a direction to look to fix the problem. New fuel pump, new fuel filters,, and the tank was cleaned and lines flushed 200 miles ago. Thank for listening, Bad FI pressure regulator. |
nordfisch |
Feb 20 2016, 05:15 PM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Bad FI pressure regulator. No. This behavior is typical for missing additive injector pulses during acceleration. The throttle-valve-switch (TPS) switches contacts when opening the throttle and sends this information to the ECU. Check and clean this unit inside- do not oil or grease the contacts. The electrical current is very low, grease will prevent contacting. Look at this: https://oldtimer.tips/en/d-jetronic/58-throotleswitch Regards Norbert |
srozick |
Feb 23 2016, 05:21 PM
Thanks Norbert.
Fuel filters first and then the TPS rebuild. Bad FI pressure regulator. No. This behavior is typical for missing additive injector pulses during acceleration. The throttle-valve-switch (TPS) switches contacts when opening the throttle and sends this information to the ECU. Check and clean this unit inside- do not oil or grease the contacts. The electrical current is very low, grease will prevent contacting. Look at this: https://oldtimer.tips/en/d-jetronic/58-throotleswitch Regards Norbert |
Lo-Fi Version | Time is now: 1st June 2024 - 02:36 PM |
