OT: Fiberglassing help, RV Repair |
rtalich |
Mar 10 2016, 04:28 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Thought I'd see if there are any glassing gurus out there in the World... and hopefully get some opinions. I have not had ANY chance to work on the car due to 'other' important issues. Suck when the car gets put on the back burner!! Anyway... I am in the process of rebuilding our RV due to water damage. I’ve gotten all the rotten wood out and am currently in the process of thinking about how I am going to build the front cap. The siding was constructed using FRP (Filon) laminated to plywood. My plan is to take the Filon material and basically glass it onto a wooden frame (see pic). I will be making some curved pieces of wood blocking that will go along the top so that when the Filon material is laid onto the wooden frame it will create the sweeping curve you normally see on the tops of RV’s. I was originally thinking of attach it using epoxy resin and fiberglass from the inside and plan to totally conceal all the wood in epoxy/fiberglass to protect it and will serve as a good water barrier. My main question is… which resin would be a better choice to use? Epoxy, polyester or vinylester? My initial thought was to use epoxy because I was not sure if the other resins will shrink at all causing the Filon to distort and not sit flat on the wood frame during the curing process. I want the Filon to sit perfectly flat on the wood frame and cave in or be sucked in which would result in being able to ‘see’ the framing from the outside (does that make sense?). On the other hand, if I could use either poly or vinyl resin, I’m thinking fiberglass mat would make for an easier application and can build up quicker. I also read that poly doesn’t really bond with wood like epoxy. Any help or suggestions would be greatly appreciated.
Thanks, Rob Attached thumbnail(s) |
r_towle |
Mar 10 2016, 08:31 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Epoxy, polyester etc is like asking if a /4 or a /6 is better when you ask boat builders.
rtalich |
Mar 10 2016, 08:47 PM
Epoxy, polyester etc is like asking if a /4 or a /6 is better when you ask boat builders. (IMG:style_emoticons/default/lol-2.gif) Although I've read in several places that epoxy is the preferred resin when applying directly on wood. And when using as a glue. I guess I'm over thinking this a bit cuz I don't want to screw it up. Materials are expensive and there's no second chances. And there are so many ways to fiberglass it's just a matter of picking one that makes sense. |
jd74914 |
Mar 10 2016, 09:14 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Epoxy, polyester etc is like asking if a /4 or a /6 is better when you ask boat builders. (IMG:style_emoticons/default/lol-2.gif) Although I've read in several places that epoxy is the preferred resin when applying directly on wood. And when using as a glue. I guess I'm over thinking this a bit cuz I don't want to screw it up. Materials are expensive and there's no second chances. And there are so many ways to fiberglass it's just a matter of picking one that makes sense. There is a debate? Epoxy is way nicer to work from a safety perspective with since you don't have to worry about the styrenes/peroxides, it is much tougher, and lasts forever. Why wouldn't you use it? As far as I know the only good thing about polyester was that it cures slightly faster and is cheap. |
porschetub |
Mar 11 2016, 01:46 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Epoxy, polyester etc is like asking if a /4 or a /6 is better when you ask boat builders. (IMG:style_emoticons/default/lol-2.gif) Although I've read in several places that epoxy is the preferred resin when applying directly on wood. And when using as a glue. I guess I'm over thinking this a bit cuz I don't want to screw it up. Materials are expensive and there's no second chances. And there are so many ways to fiberglass it's just a matter of picking one that makes sense. There is a debate? Epoxy is way nicer to work from a safety perspective with since you don't have to worry about the styrenes/peroxides, it is much tougher, and lasts forever. Why wouldn't you use it? As far as I know the only good thing about polyester was that it cures slightly faster and is cheap. Sorry but that's rubbish tell me your experience with these products..... |
Lo-Fi Version | Time is now: 10th June 2024 - 06:43 AM |
