Stock rebuild or go 2056 with D-Jet, At a crossroads |
saigon71 |
Feb 10 2016, 12:41 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm rebuilding my engine this winter. My original plan was to stay pretty much stock (including pistons & cylinders). My cam shows signs of wear on the lobes, so it needs to be replaced, along with new lifters. Piston rings are shot but P & C's are in spec. Heads will be rebuilt & all new bearings installed.
I'm sticking with D-jet and ordered a new wiring harness from Bowlsby. What I really love about my current setup with the stock 2.0 D-jet is the drivability and the overall lack of tinkering required to keep it going. I don't need a fire-breathing type 4 and don't want to mess around with external oil coolers & other add-ons because of heat concerns. This is a case of "while your in there." With the engine already torn down and for slightly more $$$ I'm considering building a 2056 with a slightly more aggressive (d-jet compatible) cam. My question is, what additional work is required to make D-jet work on a 2056 with a more aggressive cam. Is it just tweaking the MPS? Do I need to buy or install an air fuel meter? To someone who's been down this road, is it worth it? Thanks! |
saigon71 |
Mar 11 2016, 09:33 PM
Thanks for all the input, I appreciate it!
After consulting with Aircooled Racing, Dion and Dave this is the route I'm going: 2056 (flat top pistons) Lightened flywheel FAT 440MP camshaft I'm excited about this combo with the D-jet & hope it's a nice compromise of drivability and increased performance. On paper, the FAT 440MP appears to "split the difference" in lift between the stock cam and the Web 73. Here is the advertised grind for the 440MP: Intake: .413 lift, 258 duration Exhaust: .405 lift, 270 duration |
Lo-Fi Version | Time is now: 28th May 2024 - 06:55 PM |
