Time to rebuild DRLA's? |
era vulgaris |
Mar 10 2016, 05:52 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
This is a continuation from another thread, but to summarize my car very suddenly started driving like crap yesterday. In the middle of a drive it started popping and sputtering, and became pretty much undriveable. AFR was suddenly in the high teens.
At first I thought it was to do with fuel delivery. That turned out not to be the case. What I noticed today after I managed to get it to actually idle is that during warm up, cylinders 1 and 2 seem to be acting normal. But 3 and 4 heat up extremely quickly, and heat up past their normal idle temps and would probably continue to heat up well into the danger zone if I let them. I'm running DRLA 40's, and I'm still getting to know these carbs. The idle jets are clean. All I can think is that there's possibly a vacuum leak, maybe a seal or gasket failed suddenly while I was driving. They were rebuilt about 5 years ago though. Time for a rebuild? Anyone who knows Dells well know of anything I should check before I start tearing them apart? And does the rebuild kit from CB include everything I'll need? |
PotterPorsche |
Mar 11 2016, 10:34 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
What is your jetting at ? 15 is super lean . How are you measuring This? An exhaust leak will give in accurate numbers. Popping coughing = lean lean. Do you have the CB jet doctors? With the car off look down the velocity stacks. Do the accelerator pumps work? If there clogged the car is unable to transition from idles to mains.
Let's start with jetting? Air fuel mixture screw 2 turns out at each carb? 60 idles 140 mains 180 airs? |
Lo-Fi Version | Time is now: 1st June 2024 - 06:43 PM |
