> Lessons learned, ..regarding Koni Sport adjustables...
naro914
post Mar 14 2016, 07:30 AM
Losing my mind...
**NOTE: on 3/20 I changed the title of this post because at first I just had a question (this post)...but now I am sharing my experience regarding replacing your 914 suspension with Koni Adjustable shocks because a lot of people asked or seemed interested. Jump to Post 13 for "The rest of the story"....
_________________________________________________________
It's been a while since I've posted a stupid question - heck I've been so busy lately and not done much with my 914's in months that its been a while since I've posted ANYTHING at all... (Papa Smurf is away at Dawe's Motorsports winter camp spending all our retirement savings and Huey has been sitting patiently in the garage waiting for nice weather...)
So here's my dilemma: I ordered a full set of Koni Sport adjustable shocks for Huey, and I got the coil-over set up from Ground Control for the rear. They came Friday, and I was excited to get working on them Sunday (was busy Saturday).
So...after doing a bunch of things to our other cars that needed the lift, I got Huey up there, took off one of the rear Bilsteins (figured I'd start on the easy end first, easy remove and install right?) and looked at what I had in the new box, and what I had on the old shock. I realized I needed basically all the hardware that goes above the spring hat (washer, threaded collar (Porsche calls it a bushing) and rubber bushing) that was below the hole, and the bushing and washer above. Basically everything above the hat except the top nut (which they give as a lock nut).
This is where the stupid question comes in: Are there different threaded collars (bushings) for Bilstein and Koni? Look at these pictures: First one is the threaded collar, screwed all the way down on the Bilstein as it's supposed to - and the rubber bushing goes over it. The second one is as far as the collar will go...which is not at all because the thread pitch on the Koni is different!! Do I need a special threaded collar for Konis? Did they not send me something I should have? Suspension is something I've honestly never messed with...
I'm going to call Ground Control later today, but thought I would throw this out there to the World braintrust and see what responses I get since I'm SURE some of you have upgraded to Koni adjustables...
Thanks!
stugray
post Mar 14 2016, 12:17 PM
I would like to see others chime in here.
I have the same shocks, and I just looked at how mine are installed, and I dont have that piece that you have the arrow pointing to.
I just have a regular old nut on the top with the stock metal washer and the rubber "donut".
It makes me wonder if mine are installed correctly
naro914   Lessons learned   Mar 14 2016, 07:30 AM
quadracerx   I'm doing the same coilover conversion on my c...   Mar 14 2016, 07:54 AM
r_towle   At the end of the day, you could use washers/bushi...   Mar 14 2016, 11:30 AM
stugray   I would like to see others chime in here. I have ...   Mar 14 2016, 12:17 PM
naro914   Hey Rich I thought of that, but then I wondered ho...   Mar 14 2016, 12:49 PM
naro914   Well ok...learned something: The Koni Adjustables ...   Mar 14 2016, 03:02 PM
r_towle   Cool, could you post a picture of the final assemb...   Mar 14 2016, 04:08 PM
naro914   So here are the CORRECT collars: they screw on ...   Mar 16 2016, 12:38 PM
falcor75   Wow, i had the same issue but opposite a year ago ...   Mar 16 2016, 01:49 PM
naro914   Wow, i had the same issue but opposite a year ago...   Mar 16 2016, 01:59 PM
r_towle   Thank you for sharing that, and GC just got a cust...   Mar 16 2016, 02:02 PM
infraredcalvin   Nice, glad GC took care of it quickly. Thank you ...   Mar 16 2016, 09:37 PM
naro914   So here is "The Rest of the story" regar...   Mar 21 2016, 05:32 AM
gabeurgelles   So here is "The Rest of the story" rega...   Mar 22 2016, 11:25 AM
McMark   There should be a clip under the lower spring moun...   Mar 21 2016, 06:42 AM
sixnotfour   Boge struts will work also, Koni struts take a spe...   Mar 21 2016, 01:55 PM
Downunderman   I think on my six I had 8" long 275 lb spring...   Mar 22 2016, 12:03 PM
naro914   There should be a clip under the lower spring mou...   Mar 22 2016, 03:55 PM
McMark   [quote name='McMark' post='2318535' date='Mar 21 ...   Mar 23 2016, 07:02 AM
Krieger   [quote name='McMark' post='2318535' date='Mar 21...   Mar 23 2016, 08:00 AM
Krieger   I went through this problem with the rear a couple...   Mar 23 2016, 07:49 AM
Racer Chris   8" springs is the only way to get the ride he...   Mar 23 2016, 08:22 AM
McMark   I pulled apart a spare set of Koni 8241 1050SPORT ...   Mar 23 2016, 10:00 AM
Paragon   The Koni 8641-1077 Sport insert for the front 914 ...   Mar 23 2016, 07:09 PM
Gearup   The Koni 8641-1077 Sport insert for the front 914...   Apr 15 2016, 03:23 PM
rhodyguy   I bought my package from paragon via a group buy B...   Apr 15 2016, 03:51 PM
Cracker   My GC springs are 8" tall... T   Apr 16 2016, 06:15 AM
naro914   Couple things to consider: with Bilsteins, you hav...   Apr 16 2016, 07:35 AM
- Lo-Fi Version Time is now: 19th October 2026 - 02:56 AM
