> Mark's (914Rubber) Project Car
cary
post Feb 24 2016, 01:57 AM
Post #121
I've been asked by Mark to do some sheet metal/body work on his 75 2.0 Liter project car. The car arrived last Monday. But I needed to finish up a couple things on my project car and in my shop first. But I dove in this afternoon.
First task is to tidy things up after the paint stripping. Which included dropping the engine in order remove any residual media in the nooks and crannies. I was concerned with the rust prevention product that Dustless Blaster mixes with the glass media being left on and in the electrical connections. I'm a firm believer of an ounce of prevention is worth a pound of cure. I dribbled some OSPHO on a couple connectors in my white car. Not good. It ate the crap out the plating.
Here's Super In Law working on loosening up the media in order to blow it off. It will need to be steam cleaned.
Project List : So Far
Replace rear panel
Replace rear trunk floor pan
Replace back half of floor pan ............... Mark I'll send you pictures
Misc. hammer and dolly work
A few misc. patch panels
R&R both jack points and posts
This is like a new car compared to my project ...............
Observations :
Suspension Consoles look great and seem to be virgin.
Same with the motor mounts
Battery tray was changed at some time in its life
Back engine tray is bent to hell .............pushed up
Hell hole is filled with caked in blast media. Stopping at Sears on the way home for a new filter for my vacuum. I'll look closely for prior repairs.
Both the lower longs look great at first glance
Needing more research :
A few rust pits on the upper right outer wheelhouse long
But we also a have fairly good sized rust spot a little further up the upper long. Right next to the suspension console.
These are both in the double walled section of the upper long.
cary
post Mar 18 2016, 06:40 PM
Post #122
Here's the shot I forgot last night.
cary   Mark's (914Rubber) Project Car   Feb 24 2016, 01:57 AM
RobW   Good luck with your rust exploration! There al...   Feb 24 2016, 07:22 AM
RobW   Not a bad idea to add CFRs dog ears. I added them ...   Feb 24 2016, 07:22 AM
sb914   I have a good source for the rubber!   Feb 24 2016, 07:52 AM
cary   Got a late start, had to stop and set up an appoin...   Feb 25 2016, 10:51 AM
cary   I'll add the hell hole, wheelhouse rust resear...   Feb 25 2016, 10:53 AM
Mikey914   Just let me know what you need Cary. I'm back ...   Feb 25 2016, 10:23 PM
cary   Hell Hole research ............. Ok here's wha...   Feb 25 2016, 10:49 PM
cary   Mark will need to make the call on the floor pan. ...   Feb 25 2016, 11:04 PM
cary   I forgot one thing on the original list. Right inn...   Feb 25 2016, 11:08 PM
cary   Today the team was back together. Super In Law we...   Feb 25 2016, 11:33 PM
cary   I start the day digging thru my stash looking for ...   Feb 26 2016, 12:00 AM
cary   Next I need to close up some of these holes on the...   Feb 26 2016, 12:19 AM
raynekat   Dang Cary. You might just have to give up that gro...   Feb 26 2016, 04:46 AM
cary   Dang Cary. You might just have to give up that gr...   Feb 28 2016, 11:00 AM
cary   We'll talk when you get back. I don't reme...   Feb 26 2016, 11:57 PM
raynekat   We'll talk when you get back. I don't rem...   Feb 27 2016, 12:26 AM
cary   Short day. Had to drop off and pick up the A6 from...   Feb 27 2016, 12:32 AM
cary   BEFORE : [size=6]AFTER : Here's wh...   Feb 27 2016, 12:49 AM
cary   Snuck in a hour before Mark showed up on Saturday....   Feb 28 2016, 10:47 AM
JRust   Your moving right along Cary! You don't wa...   Feb 28 2016, 11:17 AM
cary   Your moving right along Cary! You don't w...   Mar 1 2016, 07:35 AM
Mikey914   Yes, He's making great progress. I have to get...   Feb 28 2016, 11:19 AM
cary   Back to work ............... Super In Law got the...   Mar 1 2016, 07:48 AM
cary   After Mark's and Mike's visit we're go...   Mar 1 2016, 07:58 AM
cary   Now on to the task at hand ............ continuing...   Mar 1 2016, 08:34 AM
BeatNavy   Rob (Beatnavy), I'm still on the same 3/8 Rot...   Mar 2 2016, 04:41 AM
cary   Now on to those pesky qtr.panel / rear panel corne...   Mar 1 2016, 08:48 AM
76-914   You are having entirely too much fun. :beer2:   Mar 1 2016, 09:01 AM
cary   You are having entirely too much fun. :beer2: ...   Mar 1 2016, 09:14 PM
cary   Next, removing the seat hardware from the floor pa...   Mar 1 2016, 09:08 AM
cary   Tuesday 3/1/16 Forgot to remove the e-brake cable...   Mar 1 2016, 09:00 PM
cary   After a good nights sleep its time to go into rust...   Mar 2 2016, 10:14 AM
Mikey914   Thanks Cary, Looks like you are going to town on t...   Mar 2 2016, 10:57 AM
mbseto   What you can't see is the HUGE mouse nest in...   Mar 2 2016, 04:09 PM
cary   Battery tray and its support hit the floor first. ...   Mar 2 2016, 08:28 PM
cary   Opened up the wheelhouse so I could continue to...   Mar 2 2016, 09:11 PM
cary   I make multiple measurements before I remove the d...   Mar 2 2016, 09:15 PM
cary   Beings that I'll be doing some work to the whe...   Mar 2 2016, 09:19 PM
cary   Things that make you go Hmmmmmmmmmmm. Can I cut of...   Mar 2 2016, 10:18 PM
McMark   Why fill these? Rosette welds to the car.   Mar 3 2016, 10:10 AM
jmitro   Why fill these? Rosette welds to the car. :...   Mar 3 2016, 10:29 AM
cary   [quote name='McMark' post='2310759' date='Mar 3 2...   Mar 3 2016, 08:49 PM
dangerranger01   I really like your work Cary and all the pictures/...   Mar 3 2016, 09:32 PM
cary   I really like your work Cary and all the pictures...   Mar 3 2016, 11:29 PM
dangerranger01   I'll take these projects on one at a time. Y...   Mar 3 2016, 11:35 PM
cary   [quote name='cary' post='2311075' date='Mar 3 201...   Mar 4 2016, 10:01 AM
dangerranger01   First I should say thank you for the compliments...   Mar 4 2016, 11:06 AM
cary   Good Luck. I couldn't find anyone on the Wes...   Mar 4 2016, 08:03 PM
raynekat   I really like your work Cary and all the picture...   Mar 6 2016, 03:38 AM
cary   I really like your work Cary and all the pictures...   Mar 17 2016, 10:55 PM
cary   Start the day with primering the refurbished piece...   Mar 3 2016, 11:54 PM
cary   Today's items sent to the refurbish workbench....   Mar 4 2016, 12:09 AM
cary   Here's a better shot of the wheelhouse with th...   Mar 4 2016, 12:42 AM
cary   Here's another area that will get close scruti...   Mar 4 2016, 12:51 AM
cary   Started the day installing the door braces. I fo...   Mar 4 2016, 08:40 PM
cary   Here's Super In Law's work on the right en...   Mar 4 2016, 09:22 PM
cary   After lunch we went to Mike's (warpig) house t...   Mar 4 2016, 10:03 PM
bigkensteele   After lunch we went to Mike's (warpig) house ...   Mar 5 2016, 02:06 PM
cary   Mark's staying with the 75-76 bumpers. So we s...   Mar 5 2016, 04:51 PM
cary   Mark's staying with the 75-76 bumpers. So we ...   Mar 7 2016, 09:51 PM
bigkensteele   Mark's staying with the 75-76 bumpers. So we ...   Mar 18 2016, 07:38 PM
cary   [quote name='cary' post='2311727' date='Mar 5 201...   Mar 19 2016, 08:39 AM
cary   Now's it time to create a 75-76 rear panel fro...   Mar 7 2016, 10:39 PM
cary   Super In Law finished up the engine shelf.   Mar 7 2016, 10:40 PM
Mikey914   WOW Cary, I was not around for a few days and you ...   Mar 8 2016, 01:06 AM
Mikey914   Looks like I'm in the market for some ss fuel ...   Mar 8 2016, 01:11 AM
cary   Start the day with a break in the rain so I make a...   Mar 8 2016, 11:26 PM
cary   Now on to filling the holes on the early rear pane...   Mar 8 2016, 11:37 PM
Mikey914   I'm not a big fan of the rear lenst due to the...   Mar 9 2016, 12:11 AM
Mikey914   One of the reasons it looked like this   Mar 9 2016, 12:12 AM
cary   Work continues on the rear panel. Cut up the old t...   Mar 10 2016, 08:47 AM
cary   Started the day with more liquid sunshine. :angry...   Mar 14 2016, 10:07 PM
cary   The RD stuff ............... I love new metal .......   Mar 15 2016, 10:32 PM
cary   Finally finished up creating the 75-76 rear panel ...   Mar 15 2016, 10:42 PM
cary   Now that I have some new replacement panels we...   Mar 15 2016, 11:13 PM
cary   I wish the replacement panel was just a bit longer...   Mar 15 2016, 11:18 PM
cary   [b]Rear Taillight Panel Install Ready to go ........   Mar 17 2016, 09:49 AM
cary   Ok, now back to documenting Wednesday's work. ...   Mar 17 2016, 08:19 PM
Cairo94507   Wow, that is some really nice work. :trophy:   Mar 17 2016, 09:01 PM
cary   Wow, that is some really nice work. :trophy: ...   Mar 17 2016, 09:05 PM
cary   Now its time to fire up the electric glue gun .......   Mar 17 2016, 09:21 PM
cary   While welding I find another problem. The right si...   Mar 17 2016, 09:32 PM
cary   Now on to fitting the rear trunk panel. Looks like...   Mar 17 2016, 09:55 PM
cary   Before I head out the door I POR15 the transmissio...   Mar 17 2016, 10:02 PM
cary   As I was doing my thing, Super In Law broke down M...   Mar 17 2016, 10:15 PM
raynekat   Looking good Cary. That rear end repair you are d...   Mar 17 2016, 11:39 PM
Mikey914   Thanks Cary, I really appreciate your attention to...   Mar 18 2016, 01:45 AM
BeatNavy   Awesome job, Cary. I love seeing the progress in ...   Mar 18 2016, 03:53 AM
sixnotfour   Cary, Great job , I think the rear trunk floor is ...   Mar 18 2016, 05:36 AM
cary   Cary, Great job , I think the rear trunk floor is...   Mar 18 2016, 07:44 AM
914werke   BTDT on the R. trunk floor repair for the late BUB...   Mar 18 2016, 07:31 AM
sixnotfour   Cary,your 73 should look like the RD panel..75-76 ...   Mar 18 2016, 12:28 PM
914_teener   Wow....that IS different. Nice work Cary.   Mar 18 2016, 01:33 PM
cary   You guys are making more work for me ... LOL It ha...   Mar 18 2016, 02:09 PM
sixnotfour   :stooges: :hissyfit: :headbang: :welder: :firs...   Mar 18 2016, 02:35 PM
cary   Here's the shot I forgot last night.   Mar 18 2016, 06:40 PM
cary   [b]Modifying RD PP335 to replicate the 75-76 rear ...   Mar 18 2016, 07:19 PM
trojanhorsepower   Great work Cary!   Mar 19 2016, 07:38 PM
cary   Great work Cary! Thanks .............. Ken...   Mar 19 2016, 08:49 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 16th June 2024 - 07:29 PM
