6 engine tin .., how well should it fit ? |
porschetub |
Mar 20 2016, 03:25 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I had to remove the right hand side to get the engine in but I'am less than happy with how all pieces seal against the rubber,I have gaps around the side sections and front apron.
The front gap is caused by the engine being to far back in the car,from what I can tell the NOS factory rubber mount is the cause,appears OP's not drilled the holes in the right place .moving the engine forward will improve the fit of the tin but not much (IMG:style_emoticons/default/sad.gif) The PO claims these were made from modified 911 tins using original 6 ones as patterns,the workmanship is really good but the fit maybe not so. I would appreciate if someone could show some pics of theirs or chuck me a link on this subject,thanks in advance. |
r_towle |
Mar 20 2016, 05:39 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes, you need to mak the rubber fit the tin.
I suspect it's th rubber at fault, not the tin. Rich |
porschetub |
Mar 20 2016, 08:34 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 10:33 AM |
