> hot start issue, is there a fall back way to start?
cooper951
post Mar 21 2016, 07:34 AM
I've had recurring issues with the hot start problem. I had the starter rebuilt with a new solenoid, and I installed the Bosch hot start relay. So far so good. But is there a way to start the car if it happens to me 50 miles from home besides push start? I tried jumping the battery connection on the solenoid to the starter with the ignition "ON" and I could hear the starter "whrrr" but it never engaged into the flywheel. TIA
cooper951
post Mar 21 2016, 11:09 AM
QUOTE(jvmarino @ Mar 21 2016, 11:31 AM) *
If your starter is good, all you need to do is grab a screwdriver and jump the battery connection on starter to the small tab on the starter that is connected to ignition switch input. Worked for me many times before I resolved my issue.
I now have a hot start relay installed, and also replaced the ground strap on the transmission.
Jim
That's what I suspected. Thanks.
cooper951   hot start issue   Mar 21 2016, 07:34 AM
zambezi   whats the condition of the ignition switch? They ...   Mar 21 2016, 09:29 AM
cooper951   whats the condition of the ignition switch? They...   Mar 21 2016, 09:35 AM
BeatNavy   [quote name='zambezi' post='2318591' date='Mar 21...   Mar 21 2016, 10:42 AM
jvmarino   If your starter is good, all you need to do is gra...   Mar 21 2016, 10:31 AM
cooper951   If your starter is good, all you need to do is gr...   Mar 21 2016, 11:09 AM
cooper951   [quote name='zambezi' post='2318591' date='Mar 2...   Mar 21 2016, 11:12 AM
Mark Henry   So you put the bosch relay in and you're still...   Mar 21 2016, 11:15 AM
cooper951   So you put the bosch relay in and you're stil...   Mar 21 2016, 11:25 AM
jimkelly   i thought hot start had to due with hot gasoline a...   Mar 21 2016, 11:28 AM
BeatNavy   i thought hot start had to due with hot gasoline ...   Mar 21 2016, 11:36 AM
ClayPerrine   i thought hot start had to due with hot gasoline ...   Mar 21 2016, 11:55 AM
Mark Henry   that aside, i put a bosch relay near my starter,...   Mar 21 2016, 12:15 PM
jimkelly   good points and info. i may switch to a ford sole...   Mar 21 2016, 12:39 PM
ClayPerrine   good points and info. i may switch to a ford sol...   Mar 21 2016, 02:35 PM
jimkelly   got ti, thanks.   Mar 21 2016, 03:24 PM
ClayPerrine   got ti, thanks. That would be correct. Both of ...   Mar 21 2016, 07:18 PM
screenguy914   It sounds like you merely energized the starter mo...   Mar 21 2016, 06:20 PM
cooper951   got ti, thanks. Where is this relay board loca...   Mar 22 2016, 04:26 AM
jimkelly   in the engine bay opposite the battery. its behin...   Mar 22 2016, 06:43 AM
cooper951   in the engine bay opposite the battery. its behi...   Mar 22 2016, 09:52 AM
- Lo-Fi Version Time is now: 12th August 2026 - 03:45 AM
