> hot start issue, is there a fall back way to start?
cooper951
post Mar 21 2016, 07:34 AM
I've had recurring issues with the hot start problem. I had the starter rebuilt with a new solenoid, and I installed the Bosch hot start relay. So far so good. But is there a way to start the car if it happens to me 50 miles from home besides push start? I tried jumping the battery connection on the solenoid to the starter with the ignition "ON" and I could hear the starter "whrrr" but it never engaged into the flywheel. TIA
jimkelly
post Mar 21 2016, 11:28 AM
Delaware USA
i thought hot start had to due with hot gasoline and fuel pump being in engine bay.
that aside, i put a bosch relay near my starter, one problem i have is from driving in bad weather, is corrosion on the terminals.
i've installed a wire from battery to a momentary switch and the end terminal is near starter, and when my car won't start, i pull the ignition wire to starter and install the wire from my half assed momentary switch and it starts fine. meaning the starter turned engine and car starts. i should wire this switch to my dash as an always available back up.
when my wires are wet and corroded, starter does not turn at all. i hate rainy salty days : (
Mark Henry
post Mar 21 2016, 12:15 PM
that's what I do!
QUOTE(jimkelly @ Mar 21 2016, 01:28 PM) *
that aside, i put a bosch relay near my starter, one problem i have is from driving in bad weather, is corrosion on the terminals.....
Jim,
I'm a Ford solenoid fanboy, one reason is because it's waterproof, only one that has failed on me is one that the metal back rusted through.
If you are going to use the bosch relay, mount it in the engine bay in a shielded area with the terminals facing down.
cooper951   hot start issue   Mar 21 2016, 07:34 AM
zambezi   whats the condition of the ignition switch? They ...   Mar 21 2016, 09:29 AM
cooper951   whats the condition of the ignition switch? They...   Mar 21 2016, 09:35 AM
BeatNavy   [quote name='zambezi' post='2318591' date='Mar 21...   Mar 21 2016, 10:42 AM
jvmarino   If your starter is good, all you need to do is gra...   Mar 21 2016, 10:31 AM
cooper951   If your starter is good, all you need to do is gr...   Mar 21 2016, 11:09 AM
cooper951   [quote name='zambezi' post='2318591' date='Mar 2...   Mar 21 2016, 11:12 AM
Mark Henry   So you put the bosch relay in and you're still...   Mar 21 2016, 11:15 AM
cooper951   So you put the bosch relay in and you're stil...   Mar 21 2016, 11:25 AM
jimkelly   i thought hot start had to due with hot gasoline a...   Mar 21 2016, 11:28 AM
BeatNavy   i thought hot start had to due with hot gasoline ...   Mar 21 2016, 11:36 AM
ClayPerrine   i thought hot start had to due with hot gasoline ...   Mar 21 2016, 11:55 AM
Mark Henry   that aside, i put a bosch relay near my starter,...   Mar 21 2016, 12:15 PM
jimkelly   good points and info. i may switch to a ford sole...   Mar 21 2016, 12:39 PM
ClayPerrine   good points and info. i may switch to a ford sol...   Mar 21 2016, 02:35 PM
jimkelly   got ti, thanks.   Mar 21 2016, 03:24 PM
ClayPerrine   got ti, thanks. That would be correct. Both of ...   Mar 21 2016, 07:18 PM
screenguy914   It sounds like you merely energized the starter mo...   Mar 21 2016, 06:20 PM
cooper951   got ti, thanks. Where is this relay board loca...   Mar 22 2016, 04:26 AM
jimkelly   in the engine bay opposite the battery. its behin...   Mar 22 2016, 06:43 AM
cooper951   in the engine bay opposite the battery. its behi...   Mar 22 2016, 09:52 AM
- Lo-Fi Version Time is now: 12th August 2026 - 03:44 AM
