Saved $2 ended up costing $1000's, - Master Cylinder Grommet Washers |
Kansas 914 |
Mar 22 2016, 11:46 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I bought my /6 last year pretty much complete. Everything was well done. 911 suspension all around. 911 brakes all around including drum emergency brake on the rears. It appeared to be a "no costs spared" restoration.
Here is the detail on just the brakes: "Brake system was upgraded in many ways. Porsche 911E front struts were installed in order to handle Porsche 911S "A" calipers. New vented front and rear 911 brake rotors. All metal brake lines and rubber hoses were replaced. The rear brake calipers are rebuilt and come from a Porsche 911S. Factory spacer shims added to the rear "M" calipers to accommodate the vented rotors. A machined spacer was added to the inside of the new rotors to align the rotor centerline to the caliper centerline. New factory rear stub axles were purchased in Germany to complete the five mounting bolt wheel conversion. The parking brake system is now the Porsche 911 type brake shoes within the brake rotor design." Last week I decided it was time to take the cars out of hibernation. The /6 was on top of the lift and the red flared car was under the lift. I got in the red car and noticed the WAS top was all but shattered. I pulled the car out of the garage and noticed it was wet. Apparently the master cylinder failed in the top car and emptied all the brake fluid into my drip pan, which eventually leaked. Besides the WAS top getting demolished, we all know what brake fluid can do to paint. I took it to 2 different body shops and am waiting for estimates. So far for paint it will need the hood, right front fender, passenger door, windshield frame, rear fender and rear deck lid. Today I got under the /6 and removed the 23mm master cylinder thinking the internal rubber seals had failed, but I don't think so. The grommets from the reservoir were damp. Upon removal I noticed neither of the grommets had the REQUIRED washer under them. I think it was just a lack of experience as to why they didn't get installed because they are 62 cents a piece at Stoddard (http://www.stoddard.com/90135593600.html). Why it failed over the Winter is a mystery as the temperature in the garage never gets below 45 degrees. There are several lessons to be learned here. #1 - If you don't know what you are doing don't do it, especially when it comes to brakes. #2 - Bulletproof your drip trays if you are storing a car underneath another one... #3 - Have good insurance even when stored in a garage. |
scotty b |
Mar 22 2016, 03:10 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Sorry to hear this. (IMG:style_emoticons/default/sad.gif) I have a local customer I did a 930 for a few years back and he left the 930 under his 356 over the winter. Went in to check on them one day and found the carbs on the 356 had leaked gas all over the tail and 1/4 panel of the 930 (IMG:style_emoticons/default/headbang.gif) Fortunately I still had enough of the original paint mix left to fix it.
Anywhere the paint got wet needs to be stripped to bare metal. If the paint wrinkled/lifted, then the primer and bondo under the paint have absorbed the brake fluid, and it WILL show itself in the future. Most likely on a nice warm sunny day. (IMG:style_emoticons/default/dry.gif) |
rick 918-S |
Mar 23 2016, 08:38 AM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Sorry to hear this. (IMG:style_emoticons/default/sad.gif) I have a local customer I did a 930 for a few years back and he left the 930 under his 356 over the winter. Went in to check on them one day and found the carbs on the 356 had leaked gas all over the tail and 1/4 panel of the 930 (IMG:style_emoticons/default/headbang.gif) Fortunately I still had enough of the original paint mix left to fix it. Anywhere the paint got wet needs to be stripped to bare metal. If the paint wrinkled/lifted, then the primer and bondo under the paint have absorbed the brake fluid, and it WILL show itself in the future. Most likely on a nice warm sunny day. (IMG:style_emoticons/default/dry.gif) Drats! (IMG:style_emoticons/default/agree.gif) and pull that windshield. Have the shop just slice the plastic clips with a razor blade. That will allow them to remove the windshield trim without damage. Anyplace the fluid could creep needs to be checked and cleaned. 3 piece windshield rubber, pull the rubber from the bright work and the bright work from the pillars, Sail panel trim, hood seal, all door weather strips and triangle window trim. Do it now or do it later. There's always time to do it right the second time... (IMG:style_emoticons/default/huh.gif) |
Kansas 914 |
Mar 23 2016, 08:45 AM
(IMG:style_emoticons/default/agree.gif) and pull that windshield. Have the shop just slice the plastic clips with a razor blade. That will allow them to remove the windshield trim without damage. Anyplace the fluid could creep needs to be checked and cleaned. 3 piece windshield trim, pull the rubber from the bright work and the bright work from the pillars, Sail panel trim, hood seal, all door weather strips and triangle window trim. Do it now or do it later. There's always time to do it right the second time... (IMG:style_emoticons/default/huh.gif) Unfortunately the PO of the red car used urethane on the windshield and then used the cheap black rubber trim. He was going for the "black out" look. Notice the triangle glass trim and door window trim. He even painted the sail panel chrome black. Something I have been wanting to change since I bought the car 8 years ago... I guess I have an opportunity now! |
Lo-Fi Version | Time is now: 11th June 2024 - 11:21 AM |
