BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 675 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
So... I currently have the engine out of my car, in the process of replacing fuel lines, shifter bushings, repainting engine tin and other general-maintenance things. In the course of cleaning up the hard-to-reach-with-the-engine-in stuff, I carefully poked into some of the aftermarket seam sealer a DAPO put over one of the trunk lid hinge mounts. I discovered cracks in the sheet metal of the mount, which is apparently what they were trying to cover up. Now I need to clean off the seam sealer so I can fix the mount.
Unfortunately, they were quite "generous" when spreading the seam sealer, and covered an area far greater than was really needed (well, was any of it really needed? (IMG:style_emoticons/default/dry.gif) ). I would like to clean off the seam sealer without destroying the original paint underneath. Do you have any suggestions? I can scrape the bulk of it off with a plastic spatula, but how do I get the residue off the paint without harming the paint? BTW, I've found that penetrating oil (both Kroil and PB Blaster) work pretty nicely for removing spray-on undercoating without hurting the paint underneath. They do take a while to soak in and loosen the undercoating when it is on thick, and there are spots on this car that prove the DAPO must have gotten a huge bulk discount.... |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
kerosene
Lo-Fi Version | Time is now: 12th July 2025 - 04:26 PM |
