Air deflection flap spring question, Which installation is correct? |
saigon71 |
Mar 27 2016, 09:16 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Wish I had paid better attention during disassembly. When loading the spring for the cooling flaps (controlled by the thermostat), does the tang of the spring go under the fan housing or under the tab that holds the bar. IE: Which install is correct? Thanks and Happy Easter!
r_towle |
Mar 27 2016, 10:08 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It should be under quite a bit of tension in position number two.
The metal tab is what you use to press it down, so make sure the other leg is the in the right place. Should be kinda hard to put in. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:30 AM |
