| malcolm2 |
Mar 16 2016, 03:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
75 1911cc with L-jet.
back in January I made this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2286395 I have been driving quite a bit since then, even took a 6 hour round trip day ride to Knoxville. My guess it 4 or 5 tanks or about 1800 miles and no issues. Same thing happened today... Driving home from work on the interstate, MPH at 80, revs about 3400. Again, going up a long low hill, not far from my exit. I could feel some spitting and sputtering. The VDO CHT ring under #3 started heading down. Dropped to 200*F. When I exited and took my foot off the gas, it died. Started right up and I made it home braking with my big toe and gassing with my little toe. This time, I have a 1/2 a tank of e10 gas (not positive on that). So it is not running empty as hoped last time. Fuel pressure was at 40 on the engine bay gauge. Other suggestions last time were the filter. I am going to remove that today. With the #3 temp as it is, I might should start there. I will try my induct timing gun on it to see about spark. Need a noid light for the injector. and i'll take a look at the plug. I'll remove the disty and take a look. But #3 seems to not be firing and generating heat. I'll update, but any other ideas? Thanks, Clark |
| pilothyer |
Mar 28 2016, 06:42 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Ideally you should have low pressure at high vacuum (idle) and higher pressure at low vacuum (acceleration) Do you have another pressure regulator you can swap with to check values at low and high vacuum conditions ? In summary what you are looking at is low pressure at high vacuum (idle 28 psi) high pressure at max throttle (32 psi) and somewhere around 30 psi at cruising.
malcolm2 Engine, Fuel or FI problems Mar 16 2016, 03:39 PM
malcolm2 Car sat for about and hour.
I started it. It idl... Mar 16 2016, 04:09 PM
r_towle sounds like it flooded, temp going down too fast, ... Mar 16 2016, 05:10 PM
malcolm2
sounds like it flooded, temp going down too fast,... Mar 16 2016, 05:18 PM
r_towle Djet floods when the MPS fails.
Ljet could flood... Mar 16 2016, 05:26 PM
era vulgaris One thing I've noticed with my 4 channel digit... Mar 16 2016, 05:27 PM
malcolm2 MAY HAVE FOUND IT....
Went to remove the #3 spark ... Mar 16 2016, 06:20 PM
SLITS http://www.classic-car-magazine.co.uk/arti...uide_... Mar 17 2016, 01:49 PM
r_towle
http://www.classic-car-magazine.co.uk/arti...uide... Mar 17 2016, 09:26 PM
r_towle I would suggest you put it together again, new plu... Mar 17 2016, 09:29 PM
Valy I hope the plug was not tighten well last time.
I ... Mar 17 2016, 10:45 PM
ClayPerrine If you are running 40 psi on the L-Jet system, the... Mar 18 2016, 01:30 PM
malcolm2 thank you gentlemen. You have given me some thing... Mar 21 2016, 06:46 AM
pilothyer
thank you gentlemen. You have given me some thin... Mar 21 2016, 06:58 AM
pilothyer Check to see if the fuel pressure goes up if you r... Mar 21 2016, 07:04 AM
malcolm2
Check to see if the fuel pressure goes up if you ... Mar 22 2016, 09:43 AM
pilothyer You are always welcome Clark............Let me kno... Mar 23 2016, 01:50 PM
malcolm2
You are always welcome Clark............Let me kn... Mar 28 2016, 06:17 PM
malcolm2
[i][b]Ideally you should have low pressure at hig... Mar 29 2016, 09:46 AM
ClayPerrine
[i][b]Ideally you should have low pressure at hi... Mar 29 2016, 11:51 AM
malcolm2
PM me your address.. . I will send you an L-Jet ... Mar 29 2016, 12:04 PM
ClayPerrine
PM me your address.. . I will send you an L-Jet... Mar 29 2016, 08:53 PM
malcolm2
[quote name='malcolm2' post='2321942' date='Mar 2... Apr 18 2016, 05:59 PM
pilothyer Once you get to the over-run condition (Cruise) va... Mar 29 2016, 07:56 PM
timothy_nd28 You adjusted the AFM too rich. You really need a A... Apr 18 2016, 10:00 PM
malcolm2
You adjusted the AFM too rich. You really need a ... Apr 19 2016, 02:55 PM
malcolm2 BTW: My work buddy has the AFR device coming to me... Apr 20 2016, 09:33 AM
malcolm2 BTW this may not be related. But I drove the car ... Apr 20 2016, 09:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:52 PM |
