Spark Plug Diagnostics for a Subaru six conversion |
nsyr |
Mar 27 2016, 03:54 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
I pulled the plugs on my eg33 conversion and cannot for the life of me decipher what is wrong. As you can see the 3 plugs on the left look fine. These were from one side of the engine. The 2 from the other side look to be carbon fouled with whitish tips? I was thinking weak ignition coils so I switched them around but nothing changed. I then swapped the o2 sensors with no change. Could oil cause dry carbon build up? The oil on the threads of the bad two plugs is from external leakage.
I did put new plugs in and only after 5 miles the plugs from the same two cylinders already had carbon build up while the other plugs are clean. The engine does have hesitation and surging but still feels pretty strong. I am thinking valve guide seals but would like another opinion. Attached thumbnail(s) |
nsyr |
Mar 27 2016, 04:08 PM
The thing that gets me though is of the three plugs from that bank only two are fouling.
porschetub |
Mar 29 2016, 02:22 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:13 AM |
