Fuel Injection: no negative reading at injectors, Car dies after 2-3 seconds |
Stanley1x |
Mar 27 2016, 12:42 PM
Newbie Group: Members Posts: 3 Joined: 10-June 15 From: san diego, ca Member No.: 18,830 Region Association: None |
My mechanic states he does not get negative at the fuel injectors (1974 1.8) and the car starts and runs only a couple seconds via the cold start plug.
Any suggestions as to why or where to to locate the problem would be greatly appreciated! Thank you |
ClayPerrine |
Mar 29 2016, 11:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,810 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
First off... I would get a new mechanic that actually knows how L-Jet works. From what he is telling you, he doesn't understand the system.
Second, this is L-Jet. It does not use trigger points in the distributor The injectors are fed power from the double relay. That is sent to the dropping resistors and from there to the injectors. The negative side of the injectors are controlled by the ECU (I use that term loosely here). They are pulsed in a batch mode by the white wire that runs from the ECU to the negative side of the coil You should have an Air Flow meter attached to the air filter in the left rear of the engine compartment. It will have a 6 pin (if it is a 74) or a 7 pin (if it is a 75) connector on the rear side, next to the tube for the engine lid release. If this is not hooked up, the injectors will fire during start, but shut down when you release the key back to run. Get a noid light ( Bosch fuel injection test light) from FLAPS. Disconnect an injector lead, and plug it in. Then try to start the car. If the light flashes during cranking but not when you release the key, then either your AFM is unplugged, the harness is broken, or the AFM is bad. I would bet on a problem with the harness. |
Lo-Fi Version | Time is now: 20th September 2024 - 06:20 PM |
