Having trouble with my 4-5 shift, real tight, It's always something simple |
cary |
Mar 31 2016, 11:08 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Haven't spent much time with my 73 2.0L. But I needed to take a look at the 4-5 shift. Shifting down from 5-4 it wants to go into 2nd. Not good ...............
I did the Chris bungee and twist the shift rod clockwise procedure. No help .......... Shifter in and out 3 or 4 times and I finally figured it out. It took a mirror and a mini flashlight. I should preface. Oilite bushing at the transmission. Tangerine bushing at the firewall. Refurbished shifter. Clutch tube reattached ahead of the shifter. What I found was that the bottom half of the primary tunnel tube support let go. Which allows the clutch tube to to rise up and drag on the shift rod. (IMG:style_emoticons/default/sad.gif) This is a shot of my rustoration project I guess the floor pan will be up for some surgery ............. With Mark's car opened up I'll be able figure how I can open it up and do the needed work with the smallest hole. |
cary |
Apr 2 2016, 07:51 AM
Got the trailer home. Installed the shifter so I could use 1 & R and loaded her on the trailer. Ready for Monday.
Here's a shot of the bottom of Mark's car. Looks like the bottom of his primary support has worn thru also. I guess I'll fab up a couple pieces. In close examination I do see a couple cutting wheel cuts on the bottom of Mark's accelerator tube. The bottom of the floor pan was still covered with some of the blasting media so I didn't examine it too closely. It must have been opened up before. Funny thing is they must not have opened up a big enough hole. For they cut a hole in the tunnel top too. Or vice versa. They opened up the top and figured out they didnt have enough space to work. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:56 PM |
