> how to KEEP teener running in hot weather, cool and cold weather good for 74 teener - WHY
9fourteen14
post Mar 30 2016, 05:16 PM
PORSCHE LUVA
I have stated my question in a way to get the most responses/help/ideas possible.
when the weather is warm to hot and I have driven it for 4 miles or so, It really
wants to die. and then if i drive it any longer it will die in the hot weather.
THEN
after just waiting until (it seems like cools off - because engine if not running
it will start right back up and go.) in the hot weather.
I know others have experienced something like this BUT
I have never seen any answers that come close to my situation.
thanks for your help.
914 luva
ClayPerrine
post Apr 2 2016, 08:37 AM
I agree with replacing the fuel lines. Watching your 914 burn is heartbreaking. I know, Betty and I lived it.
For your running issue, it really sounds like vapor lock. Gasoline boils at approximately 90 degrees Fahrenheit. The fuel pump for a 74 and older 914 is mounted right next to the heat exchangers. So when you turn the car off, the gasoline in the pump stops moving and the heat radiated from the engine and heat exchangers boils the gas in the pump. There is no pump in existence that can pump a gaseous substance. It has to be liquid. So you are stuck on the side of the road with no fuel pressure. If you wait until the car cools down, it will start up and run fine.
The reason this normally doesn't happen when the car is moving is because the gasoline moves through the pump before it can boil. But it can happen. Get in the desert with high temps and it would be possible to generate enough heat to boil the gas while it moves through the pump. It's possible, but highly unlikely.
Porsche realized this was a problem, and on the 75 and 76 914s, they moved the pump up front under the fuel tank. That's what I suggest you do. But don't do it with the stock fuel lines 40+ years of existence has made them brittle and prone to breakage. Pushing 30+ psi down old brittle lines could be disastrous. I suggest getting a fuel line kit from Tangerine Racing and installing it. It is invisible unless someone crawls under the car, so you won't mess up your originality.
Dtjaden
post Apr 2 2016, 09:53 AM
Back in the day (1973) I had a new 914 and started having the vapor lock problem in the Minnesota summer. I simply added a second low pressure pump, a Holly if I remember correctly, at the gas tank end to always keep pressure on the line to the FI pump. Problem solved.
I would also recommend replacing the old fuel lines.
9fourteen14   how to KEEP teener running in hot weather   Mar 30 2016, 05:16 PM
76-914   Might help if you state which year model, engine s...   Mar 30 2016, 05:27 PM
Tom_T   Might help if you state which year model, engine ...   Mar 30 2016, 06:01 PM
era vulgaris   Vapor lock maybe? Where is your fuel pump located...   Mar 30 2016, 06:07 PM
9fourteen14   Vapor lock maybe? Where is your fuel pump locate...   Apr 1 2016, 02:03 PM
Cuda911   Based on the minimal info., I'm going to sugge...   Mar 30 2016, 07:15 PM
r_towle   Happy to help, sounds like it needs some basic mai...   Mar 30 2016, 07:28 PM
76-914   :bump:   Mar 31 2016, 08:08 AM
BeatNavy   Vapor lock, as I understand it, is when the fuel l...   Apr 1 2016, 02:12 PM
9fourteen14   Vapor lock, as I understand it, is when the fuel ...   Apr 1 2016, 08:47 PM
Hank914   Vapor lock, as I understand it, is when the fuel...   Apr 1 2016, 09:04 PM
9fourteen14   Vapor lock, as I understand it, is when the fuel...   Apr 3 2016, 08:36 AM
74ravenna   Nothing to do with vapor lock and even though I do...   Apr 2 2016, 06:06 AM
74ravenna   "Nothing to do with vapor lock" meaning ...   Apr 2 2016, 06:08 AM
ClayPerrine   I agree with replacing the fuel lines. Watching y...   Apr 2 2016, 08:37 AM
Dtjaden   Back in the day (1973) I had a new 914 and started...   Apr 2 2016, 09:53 AM
zipedadoo   One thing it could be is too much blow by. If all ...   Apr 3 2016, 10:10 AM
BeatNavy   I didn't necessarily think vapor lock was the ...   Apr 3 2016, 12:30 PM
Mark Henry   You know the other reason for overheating could be...   Apr 3 2016, 01:23 PM
The Cabinetmaker   In the seventies, my 73 1.7 would die while drivin...   Apr 3 2016, 01:47 PM
6freak   when i installed the new SS lines i wrapped the li...   Apr 4 2016, 03:17 PM
- Lo-Fi Version Time is now: 4th July 2025 - 12:54 PM
