Throttle Position Switch, I'm confused |
Rhodes71/914 |
Sep 30 2004, 08:22 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Here is some background -
Attempting to get my 71 1.7 D-jet tuned here is what has been done so far New: plugs, wires, cap, rotor, points, condenser, changed out FI trigger points with clean ones (that made a huge dif) Valves adj, dwell set, timing set. Idle is ok, timing set 27 deg BTDC engine revs fine in neutral. No power when engine is under load. Went to calibrate TPS per pelican tech article. Problem is that my TPS has only 4 pins and the one in the article has five. Plug matches my TPS Any ideas? Would post a pic but I keep getting a timeout error so gave up on that |
Bruce Allert |
Oct 4 2004, 07:57 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Just looked at 2 of my TPS's from my old (blown up) 1.7 and neither had any wires in them. It is a 73 & ot a 71. Also it is an 021 TPS. Wonder if these would work on yours?
......b |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:20 AM |
