> jim kelly's 1975 914 suby build, water pump housing and header interference ???
jimkelly
post Sep 26 2015, 10:40 AM
Delaware USA
i have a 1975 914 roller and a a few ej22 engines and a couple of suby 5 spd transaxles
https://www.diyautotune.com/shop/megasquirt...ed/microsquirt/
microsquirt with 8" harness $370
GM clt sensor 3/8 npt $17
GM iat sensor 3/8 npt $22
GM map sensor $75
3/8 npt tap $10
18x1.5 tap $12
18x1.5 bung for aem o2 sensor $4
AEM 30-4110 $165
Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat $30
VW bug Beetle golf oem 2.0 ignition coil pack assembly 032905106b $20
Subaru WRX OEM Crankshaft Timing Sprocket pn-13021AA141 $30
celica radiator 2 row - $170 (see post #2 and my v8 thread)
exhaust header - $35 ebay (see post #152) (decided to go with wrx oem stock header for compactness)
stainless fuel lines - $99 tangerine - 8mm supply and 8mm return
stopper drive pinion - made myself
http://www.914world.com/bbs2/index.php?showtopic=104513
stock 914 axles machined on one end - $150 Dutchman
tires - 185x50x15 - $300+-[/b]
engine cradle and trans hangars - mepstein $550 (see post #32)
mr2 shifter - $35 ebay
shift knob ebay $12 (see post #170)
front bumper grills - $35 dflesburg
stock style fuses - ebay $13
set of speed bleeders - $30 pelican
brake peddle switch - $24 pelican
ebrake handle assy with cable and equalizer - $56 bdstone914
lug bolts to roll car around my garage - free mark epstein
set of nice complete late model doors - $150 (thanks lorin, series9, rat rod charlie)
center section of fuse box - free mark epstein
a front steel bumper - free mark epstein
late model tach with single directional indicator - cabinetmaker $40 shipped : )
two pair front amber lens bought from 914rubber for both my cars.
https://weddleindustries.com/products/1000186/1001853 - flange $50 shipped type 1 to type 2/4
starter 23300AA560 - http://www.914world.com/bbs2/index.php?showtopic=303903
looking forward to...
good fuel mileage
modern fuel injection
modern 5spd transaxle - useable 1st gear for taking off from dead stop & in traffic
light weight car
big space in engine bay
running some low profile 15 inch tires on 5.5" wheels - maybe 185x50x15
reference materials and links...
http://www.shoptalkforums.com/viewtopic.php?t=136053
http://www.surrealmirage.com/subaru/swap/electrical.html
http://legacycentral.org/
http://www.northursalia.com/modifications/...lschematics.pdf
http://www.main.experiencetherave.com/subaru_manual_scans/
vanagon related links...
http://subaruvanagon.com/conversion_services_Wiring.htm
https://smallcar.com/vanagon/subaru-vanagon...cation-kit.html
http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx
http://www.rockymountainwesty.com/v/vspfil...nstructions.pdf
http://www.weidefamily.net/vanagon/HTML/05/main.html
http://www.ultimatesubaru.org/forum/topic/...iring-diagrams/
http://www.numbchuxconversions.com/Files/Harness%20info.pdf
http://consumerguide.com/used/1990-94-subaru-legacy/
pulling ej22 harness from subaru (Tim Seward) per tim 90 and 91 harnesses are same
https://www.youtube.com/watch?v=GfQJnZBljsw
be sure to watch all (busaru) segments
https://www.youtube.com/watch?v=ENm6S3WkKJc
Subaru engine test stand (Jeff Robenolt)
https://www.youtube.com/watch?v=_IN5rfK9a_8
jimkelly
post Apr 6 2016, 06:02 PM
Delaware USA
got me second ej22 today $100.
Andyrew
post Apr 12 2016, 03:34 PM
Spooling.... Please wait
QUOTE(jimkelly @ Apr 6 2016, 05:02 PM) *
You and your truck amaze me!
jimkelly   jim kelly's 1975 914 suby build   Sep 26 2015, 10:40 AM
jimkelly   this ebay radiator was mentioned by a member. the...   Sep 29 2015, 02:30 PM
jimkelly   some sensor fake output info... from tonyakavw an...   Sep 29 2015, 02:32 PM
r_towle   Wait, what? Don't you have a v8?   Sep 29 2015, 04:04 PM
Smallblockbug   Im pretty sure this is his other car. But yes he h...   Sep 29 2015, 04:31 PM
jimkelly   i have a wife, 2 boys, and two 914s. that is about...   Sep 29 2015, 06:31 PM
Stacks914   I am sorry did you mention fuel mileage??? LOL jk...   Sep 30 2015, 01:48 AM
jimkelly   YES, yes i did. it will be my daily driver once c...   Sep 30 2015, 07:01 AM
mepstein   YES, yes i did. it will be my daily driver once ...   Sep 30 2015, 07:09 AM
76-914   When does the build start? Not a fan of acquisitio...   Sep 30 2015, 09:21 AM
mepstein   When does the build start? Not a fan of acquisiti...   Sep 30 2015, 09:39 AM
76-914   When does the build start? Not a fan of acquisit...   Sep 30 2015, 04:00 PM
mepstein   [quote name='mepstein' post='2245415' date='Sep 3...   Sep 30 2015, 05:52 PM
jimkelly   i'll try to blend ACQUISITION with ACTUAL BUIL...   Sep 30 2015, 06:53 PM
mgp4591   i'll try to blend ACQUISITION with ACTUAL BUI...   Oct 1 2015, 09:06 PM
jimkelly   $35 ebay actual unit as received   Oct 1 2015, 06:33 PM
A&P Mech   All those pieces and parts look familiar. :) What...   Oct 1 2015, 06:50 PM
jimkelly   Dutchman has been recommended by bigkat_83 who is ...   Oct 2 2015, 08:52 AM
76-914   Dutchman has been recommended by bigkat_83 who is...   Oct 2 2015, 09:47 AM
mgp4591   Sweet idea for the axles- I may just send my SVX a...   Oct 2 2015, 10:38 PM
jimkelly   sawtooths axles >> has anyone used this dim...   Oct 3 2015, 06:12 AM
76-914   sawtooths axles >> has anyone used this di...   Oct 3 2015, 08:20 AM
jimkelly   your conversion was epic - others can see it here....   Oct 3 2015, 10:24 AM
jimkelly   why I MUST HAVE a Subaru engine and trans :D AL...   Oct 3 2015, 06:15 AM
Chris H.   why I MUST HAVE a Subaru engine and trans :D ...   Oct 3 2015, 01:34 PM
Justinp71   why I MUST HAVE a Subaru engine and trans :D ...   Apr 1 2016, 05:37 PM
jimkelly   OD of splined end of stock 914 axle is 1.066. wha...   Oct 7 2015, 12:56 PM
76-914   OD of splined end of stock 914 axle is 1.066. wh...   Oct 12 2015, 08:20 PM
mepstein   Jim - if you or someone will tell me how to remove...   Oct 7 2015, 03:59 PM
mgp4591   Jim - if you or someone will tell me how to remov...   Oct 7 2015, 04:53 PM
jimkelly   once upon a time, i had a legacy parts car and rem...   Oct 7 2015, 04:03 PM
jimkelly   Ms_UZ43u4CQ   Oct 7 2015, 05:10 PM
mepstein   Thanks guys. I'll probably cheat and have on...   Oct 7 2015, 06:08 PM
jimkelly   decided to drive the pickup truck to mark's sh...   Oct 9 2015, 11:34 AM
jimkelly   finally got my 1975 back onto some wheels and tire...   Oct 10 2015, 04:10 PM
jimkelly   how could i best protect these pin holed longs wit...   Oct 12 2015, 11:07 AM
Andyrew   how could i best protect these pin holed longs wi...   Oct 15 2015, 04:15 PM
jimkelly   my buddy - rat rod charlie - is on his way to dayt...   Oct 12 2015, 03:38 PM
jimkelly   got me some doors coming via series9's shop.   Oct 15 2015, 02:51 PM
jimkelly   my head light question thread at this link... pics...   Oct 16 2015, 12:00 PM
jimkelly   decided that I will just put a delrin spacer here ...   Oct 18 2015, 05:54 AM
jimkelly   new doors coming home today. guess i'll put w...   Oct 30 2015, 02:56 PM
flmont   Jim,..how do U intend to run the water lines under...   Oct 30 2015, 10:12 PM
jimkelly   under - it is tried and true - but thru longs give...   Oct 30 2015, 10:36 PM
rightpedal   Jim I laugh every time I see the "pickup...   Oct 31 2015, 05:16 AM
jimkelly   white doors are back on my 1975 and red doors are ...   Oct 31 2015, 04:37 PM
914forme   And to think I just man handle doors in place, put...   Oct 31 2015, 05:09 PM
jimkelly   thank god I had the hoist... no way could I have i...   Oct 31 2015, 06:50 PM
jimkelly   yesterday I picked up a fuse box section and a fro...   Nov 1 2015, 08:03 AM
mepstein   Save your old fuse panel in case you or someone el...   Nov 1 2015, 09:07 AM
jimkelly   mark - that is awesome - I am so glad I got a kid ...   Nov 1 2015, 09:23 AM
mepstein   mark - that is awesome - I am so glad I got a kid...   Nov 1 2015, 09:33 AM
jimkelly   just stripped down the bumper. i'll be return...   Nov 1 2015, 10:26 AM
jimkelly   well, I still don't understand how you guys ac...   Nov 7 2015, 08:27 AM
Andyrew   well, I still don't understand how you guys a...   Nov 7 2015, 11:18 AM
mepstein   Pm me your address and I'll send down some cli...   Nov 7 2015, 08:49 AM
jimkelly   mark, how about I visit next week, I need to bring...   Nov 7 2015, 08:58 AM
mepstein   mark, how about I visit next week, I need to brin...   Nov 7 2015, 09:09 AM
jimkelly   guess if I just remove lens, maybe I would have a ...   Nov 7 2015, 11:46 AM
914forme   Small bit and bit holder does the trick also, remo...   Nov 7 2015, 02:03 PM
jimkelly   (( driver bit in fingers seems like a decent solut...   Nov 7 2015, 02:19 PM
jimkelly   since i have been getting my lights and guages rei...   Nov 9 2015, 04:37 PM
jimkelly   it turns out that my car has dash wiring for EGR a...   Nov 11 2015, 10:22 AM
jimkelly   tested my buddy's theory that my battery charg...   Nov 14 2015, 09:45 AM
jimkelly   did a loose bolt/wire check and found 3 nuts at bo...   Nov 15 2015, 05:39 PM
jimkelly   got me some stuff from 914rubber :)   Nov 25 2015, 09:41 PM
jimkelly   did a little something on my 75 today. got some s...   Nov 29 2015, 12:27 PM
jimkelly   think i found my parts car, a lowly ej22 in need o...   Mar 31 2016, 02:18 PM
matthepcat   ^^That motor has a factory forged crank ^^ You ca...   Mar 31 2016, 02:47 PM
jimkelly   one step closer... with a 1990 subaru legacy awd.....   Mar 31 2016, 08:26 PM
76-914   one step closer... BUT NOT TO TURBO :D time to...   Apr 1 2016, 08:41 AM
jimkelly   i'm concerned. i knew the engine has some iss...   Apr 1 2016, 01:10 PM
zipedadoo   What year is the subaru? I used a 1996 ej22. I fou...   Apr 1 2016, 01:54 PM
jimkelly   1990 subaru legacy awd.. must have been sitting fo...   Apr 1 2016, 02:29 PM
Chris H.   No the car in that clip is a 4 cylinder turbo car....   Apr 1 2016, 10:21 PM
jimkelly   all he said was that he stopped running it cause h...   Apr 2 2016, 05:57 AM
jimkelly   ok, engine runs but weak. seems spark is ok but n...   Apr 6 2016, 06:45 AM
jimkelly   got me second ej22 today $100.   Apr 6 2016, 06:02 PM
Andyrew   got me second ej22 today $100. You and you...   Apr 12 2016, 03:34 PM
jimkelly   my 1990 subaru legacy 5spd awd, pulling harness, t...   Apr 12 2016, 03:06 PM
jimkelly   thank you andy :D at a gas station on the way b...   Apr 12 2016, 04:11 PM
jimkelly   great thread on repairing shielded suby wires. htt...   May 29 2016, 10:27 AM
jimkelly   pulled engine and trans last night. made a cradle ...   Jun 10 2016, 06:07 PM
76-914   The Fun begins Jim. :popcorn: You may need a few ...   Jun 10 2016, 06:24 PM
jimkelly   I have several wires to fix on my harness. someho...   Jun 11 2016, 03:19 PM
mepstein   I have several wires to fix on my harness. someh...   Jun 11 2016, 03:43 PM
arkitect   got me second ej22 today $100. Cool use of...   Jun 10 2016, 10:37 PM
jimkelly   thanks :) got me second ej22 today $100....   Jun 11 2016, 03:16 PM
jimkelly   ambitious, no. :poke: poking myself :D frugal...   Jun 11 2016, 04:35 PM
76-914   ambitious, no. :poke: poking myself :D fruga...   Jun 12 2016, 03:24 PM
mepstein   ambitious, no. :poke: poking myself :D frug...   Jun 12 2016, 05:46 PM
rightpedal   I might be able to help with the cradle. Want to ...   Jun 12 2016, 07:00 PM
jimkelly   I already have the suby cradle and trans hangers f...   Jun 12 2016, 07:21 PM
jimkelly   i bit off topic but i am making my recently bought...   Jun 27 2016, 05:58 AM
jimkelly   engine stand getting closer to finished and closer...   Jul 1 2016, 09:10 PM
jimkelly   latest of engine on stand... amnd video of harness...   Jul 13 2016, 04:51 PM
jimkelly   decided to try a microsquirt based on many youtube...   Apr 5 2017, 06:15 AM
76-914   Good to see you haven't given up. MS is easier...   Apr 5 2017, 07:59 AM
jimkelly   guess i'll cross that bridge if i ever get the...   Apr 5 2017, 10:46 AM
jpnovak   MS2 ECU board fits nicely inside a stock Suby ECU ...   Apr 5 2017, 02:48 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 25th September 2026 - 12:01 PM
