| tomeric914 |
Apr 15 2016, 12:03 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Seeing that we'll be putting 2800+ miles on the 914 a couple of weeks (http://www.914world.com/bbs2/index.php?showtopic=278089) from now at, ahem, highway speeds and may need another form of entertainment besides the 500 watt Bluetooth amp. Has anyone mounted a CB antenna on a 914? If so, what worked for you?
I'm thinking I can fabricate a mount to bolt up to the threaded inserts under the factory "roll bar" meant for the accessory ski rack and easily run the wire inside from there. |
| billh1963 |
Apr 15 2016, 12:08 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Seeing that we'll be putting 2800+ miles on the 914 a couple of weeks (http://www.914world.com/bbs2/index.php?showtopic=278089) from now at, ahem, highway speeds and may need another form of entertainment besides the 500 watt Bluetooth amp. Has anyone mounted a CB antenna on a 914? If so, what worked for you? I'm thinking I can fabricate a mount to bolt up to the threaded inserts under the factory "roll bar" meant for the accessory ski rack and easily run the wire inside from there. Why not use one with a magnetic base? Midlands Great reviews: Lil Wilson |
| tomeric914 |
Apr 15 2016, 02:24 PM
| billh1963 |
Apr 15 2016, 02:31 PM
Why not use one with a magnetic base? The roof is fiberglass? You can mount it on the engine lid, rear trunk, front fender, etc. I assume you want something you can easily remove later. If you want a permanent mount then that's a different issue. |
tomeric914 CB Antenna - anyone mounted one on a 914? Apr 15 2016, 12:03 PM
sb914
Seeing that we'll be putting 2800+ miles on t... Apr 15 2016, 02:49 PM
Elliot Cannon CB? Do people still use those? :lol: Apr 15 2016, 03:07 PM
cary
I'm ... Apr 15 2016, 07:32 PM
Larmo63 https://www.youtube.com/watch?v=Sd5ZLJWQmss
Can w... Apr 15 2016, 03:17 PM
anderssj
Seeing that we'll be putting 2800+ miles on t... Apr 15 2016, 03:41 PM
bandjoey Bumper mount via the tow hook hole? Then get one ... Apr 15 2016, 05:32 PM
Amphicar770 About 2 years ago I hooked a CB up in my SUV for a... Apr 15 2016, 07:29 PM
Tom_T
Seeing that we'll be putting 2800+ miles on t... Apr 15 2016, 10:19 PM
tomeric914 Thanks for all the suggestions!
I had the CB ... Apr 19 2016, 10:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:47 PM |
