| napasteve |
Apr 15 2016, 04:19 PM
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 526 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California
How do you avoid kinking the fuel lines below the gas tank?
Now that I'm installing a new fuel pump, I thought it might be a good idea to be sure that the new SS fuel lines were not obstructed. So I poured a gallon of gas into the tank to confirm gas flow back to below the engine. No gas came out. I then put in about 5 gallons of gas and visually confirmed that the fuel was completely covering the sock. Still no flow. Ugh. In retrospect, my old fuel pump may have been OK; it was just starved for fuel. (That's OK as a new fuel pump is probably a good idea anyway.) So out with the fuel tank again. As I pulled the tank, I could see that the larger line was kinked. With the tank out, I blew air thru the lines; no obstruction. So what is the secret? Is there a standard length of hose between the tank and the SS lines? Once the tank is back in place, it's really hard to examine the hoses. FYI I'm using the 5/16 and 3/8 fuel lines that Tangerine supplied (Gates Barricade MPI Fuel Injection hose). Any advise is appreciated. |
| pilothyer |
Apr 15 2016, 04:34 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) Best method is to attach the lines after the tank is installed. This is easily done thru the access hole under the car.
| ejm |
Apr 15 2016, 05:07 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
napasteve How do you avoid kinking the fuel lines below the gas tank? Apr 15 2016, 04:19 PM
pete000 I have seen people put the lines in a loop. I trie... Apr 15 2016, 04:28 PM
JPA914
I have seen people put the lines in a loop. I tri... Apr 16 2016, 10:17 AM
:agree: Best method is to attach the lines afte... Apr 15 2016, 05:13 PM
ndfrigi yes make the other end of the fuel hose (tank side... Apr 15 2016, 04:36 PM
porschetub
yes make the other end of the fuel hose (tank sid... Apr 17 2016, 02:59 PM
SirAndy I make sure they are long enough to coil under the... Apr 15 2016, 05:15 PM
76-914
I make sure they are long enough to coil under th... Apr 15 2016, 06:39 PM
napasteve Another dumb question: I can see there's a hol... Apr 15 2016, 05:29 PM
RobW
Another dumb question: I can see there's a ho... Apr 15 2016, 05:31 PM
Steve I've used wire protector crap and tie wrapped ... Apr 15 2016, 05:59 PM
Amphicar770 Getting tank back in without kinking lines was a m... Apr 15 2016, 07:20 PM
Jeff Bowlsby The FWSM has the lengths of these two hoses, summa... Apr 16 2016, 09:16 AM
Racer Chris 5/16" hose isn't much of a problem, but t... Apr 16 2016, 10:11 AM
napasteve Success!
The tank is back in and the lines ar... Apr 16 2016, 12:17 PM
914_teener I used the loop method as well but zip tied them t... Apr 16 2016, 08:20 PM
boxsterfan I tried and tried and tried with the 30R9 fuel hos... Apr 16 2016, 08:49 PM
napasteve Fuel pump and filter in. After some brief coughing... Apr 17 2016, 11:04 AM
napasteve Now another question: I'm thinking I should ho... Apr 17 2016, 11:10 AM
914_teener Yes. Apr 17 2016, 11:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 05:31 AM |
