> How do you avoid kinking the fuel lines below the gas tank?, Update: It's Alive! It's Alive!
napasteve
post Apr 15 2016, 04:19 PM
914 driving winemaker
Now that I'm installing a new fuel pump, I thought it might be a good idea to be sure that the new SS fuel lines were not obstructed. So I poured a gallon of gas into the tank to confirm gas flow back to below the engine. No gas came out. I then put in about 5 gallons of gas and visually confirmed that the fuel was completely covering the sock. Still no flow. Ugh.
In retrospect, my old fuel pump may have been OK; it was just starved for fuel. (That's OK as a new fuel pump is probably a good idea anyway.)
So out with the fuel tank again. As I pulled the tank, I could see that the larger line was kinked. With the tank out, I blew air thru the lines; no obstruction.
So what is the secret?
Is there a standard length of hose between the tank and the SS lines? Once the tank is back in place, it's really hard to examine the hoses.
FYI I'm using the 5/16 and 3/8 fuel lines that Tangerine supplied (Gates Barricade MPI Fuel Injection hose).
Any advise is appreciated.
napasteve
post Apr 15 2016, 05:29 PM
Another dumb question: I can see there's a hole down under the fuel tank toward the front of the car. Does one need to remove the panel (some kind of rock guard?) bolted to the bottom that partially covers the access hole? Looks like 4 bolts?
napasteve   How do you avoid kinking the fuel lines below the gas tank?   Apr 15 2016, 04:19 PM
pete000   I have seen people put the lines in a loop. I trie...   Apr 15 2016, 04:28 PM
JPA914   I have seen people put the lines in a loop. I tri...   Apr 16 2016, 10:17 AM
pilothyer   :agree: Best method is to attach the lines after...   Apr 15 2016, 04:34 PM
ejm   Best method is to attach the lines after the tank...   Apr 15 2016, 05:07 PM
mepstein   :agree: Best method is to attach the lines afte...   Apr 15 2016, 05:13 PM
ndfrigi   yes make the other end of the fuel hose (tank side...   Apr 15 2016, 04:36 PM
porschetub   yes make the other end of the fuel hose (tank sid...   Apr 17 2016, 02:59 PM
SirAndy   I make sure they are long enough to coil under the...   Apr 15 2016, 05:15 PM
76-914   I make sure they are long enough to coil under th...   Apr 15 2016, 06:39 PM
napasteve   Another dumb question: I can see there's a hol...   Apr 15 2016, 05:29 PM
RobW   Another dumb question: I can see there's a ho...   Apr 15 2016, 05:31 PM
Steve   I've used wire protector crap and tie wrapped ...   Apr 15 2016, 05:59 PM
Amphicar770   Getting tank back in without kinking lines was a m...   Apr 15 2016, 07:20 PM
Jeff Bowlsby   The FWSM has the lengths of these two hoses, summa...   Apr 16 2016, 09:16 AM
Racer Chris   5/16" hose isn't much of a problem, but t...   Apr 16 2016, 10:11 AM
napasteve   Success! The tank is back in and the lines ar...   Apr 16 2016, 12:17 PM
914_teener   I used the loop method as well but zip tied them t...   Apr 16 2016, 08:20 PM
boxsterfan   I tried and tried and tried with the 30R9 fuel hos...   Apr 16 2016, 08:49 PM
napasteve   Fuel pump and filter in. After some brief coughing...   Apr 17 2016, 11:04 AM
napasteve   Now another question: I'm thinking I should ho...   Apr 17 2016, 11:10 AM
914_teener   Yes.   Apr 17 2016, 11:15 AM
- Lo-Fi Version Time is now: 2nd May 2026 - 05:31 AM
