> Engine, Fuel or FI problems, spitting and sputtering again
malcolm2
post Mar 16 2016, 03:39 PM
75 1911cc with L-jet.
back in January I made this post:
http://www.914world.com/bbs2/index.php?s=&...t&p=2286395
I have been driving quite a bit since then, even took a 6 hour round trip day ride to Knoxville. My guess it 4 or 5 tanks or about 1800 miles and no issues.
Same thing happened today... Driving home from work on the interstate, MPH at 80, revs about 3400. Again, going up a long low hill, not far from my exit. I could feel some spitting and sputtering.
The VDO CHT ring under #3 started heading down. Dropped to 200*F. When I exited and took my foot off the gas, it died. Started right up and I made it home braking with my big toe and gassing with my little toe.
This time, I have a 1/2 a tank of e10 gas (not positive on that). So it is not running empty as hoped last time. Fuel pressure was at 40 on the engine bay gauge.
Other suggestions last time were the filter. I am going to remove that today.
With the #3 temp as it is, I might should start there. I will try my induct timing gun on it to see about spark. Need a noid light for the injector. and i'll take a look at the plug.
I'll remove the disty and take a look. But #3 seems to not be firing and generating heat.
I'll update, but any other ideas?
Thanks,
Clark
timothy_nd28
post Apr 18 2016, 10:00 PM
You adjusted the AFM too rich. You really need a AFR gauge to readjust the AFM. On my 1911 build, I relaxed the AFMs clock spring 3 gear teeth. I remember you told me before that you went more than that on your AFM. Replace the plugs, keep the stock gap for now, and drive it for a few days with the AFR gauge attached, document the ratios you see and what speeds you see that at.
malcolm2   Engine, Fuel or FI problems   Mar 16 2016, 03:39 PM
malcolm2   Car sat for about and hour. I started it. It idl...   Mar 16 2016, 04:09 PM
r_towle   sounds like it flooded, temp going down too fast, ...   Mar 16 2016, 05:10 PM
malcolm2   sounds like it flooded, temp going down too fast,...   Mar 16 2016, 05:18 PM
r_towle   Djet floods when the MPS fails. Ljet could flood...   Mar 16 2016, 05:26 PM
era vulgaris   One thing I've noticed with my 4 channel digit...   Mar 16 2016, 05:27 PM
malcolm2   MAY HAVE FOUND IT.... Went to remove the #3 spark ...   Mar 16 2016, 06:20 PM
SLITS   http://www.classic-car-magazine.co.uk/arti...uide_...   Mar 17 2016, 01:49 PM
r_towle   http://www.classic-car-magazine.co.uk/arti...uide...   Mar 17 2016, 09:26 PM
r_towle   I would suggest you put it together again, new plu...   Mar 17 2016, 09:29 PM
Valy   I hope the plug was not tighten well last time. I ...   Mar 17 2016, 10:45 PM
ClayPerrine   If you are running 40 psi on the L-Jet system, the...   Mar 18 2016, 01:30 PM
malcolm2   thank you gentlemen. You have given me some thing...   Mar 21 2016, 06:46 AM
pilothyer   thank you gentlemen. You have given me some thin...   Mar 21 2016, 06:58 AM
pilothyer   Check to see if the fuel pressure goes up if you r...   Mar 21 2016, 07:04 AM
malcolm2   Check to see if the fuel pressure goes up if you ...   Mar 22 2016, 09:43 AM
pilothyer   You are always welcome Clark............Let me kno...   Mar 23 2016, 01:50 PM
malcolm2   You are always welcome Clark............Let me kn...   Mar 28 2016, 06:17 PM
pilothyer   Ideally you should have low pressure at high vacuu...   Mar 28 2016, 06:42 PM
malcolm2   [i][b]Ideally you should have low pressure at hig...   Mar 29 2016, 09:46 AM
ClayPerrine   [i][b]Ideally you should have low pressure at hi...   Mar 29 2016, 11:51 AM
malcolm2   PM me your address.. . I will send you an L-Jet ...   Mar 29 2016, 12:04 PM
ClayPerrine   PM me your address.. . I will send you an L-Jet...   Mar 29 2016, 08:53 PM
malcolm2   [quote name='malcolm2' post='2321942' date='Mar 2...   Apr 18 2016, 05:59 PM
pilothyer   Once you get to the over-run condition (Cruise) va...   Mar 29 2016, 07:56 PM
timothy_nd28   You adjusted the AFM too rich. You really need a A...   Apr 18 2016, 10:00 PM
malcolm2   You adjusted the AFM too rich. You really need a ...   Apr 19 2016, 02:55 PM
malcolm2   BTW: My work buddy has the AFR device coming to me...   Apr 20 2016, 09:33 AM
malcolm2   BTW this may not be related. But I drove the car ...   Apr 20 2016, 09:40 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:29 PM
