> 914-4 Battery?
914
post May 3 2016, 08:17 AM
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914
post May 3 2016, 06:10 PM
Thanks everyone for the reply's.I got the Bosch 96R..
914
913B
post May 3 2016, 08:16 PM
QUOTE(914 @ May 3 2016, 05:10 PM) *
914
neverheard of a bosch battery,, if you find the time maybe attach an installed pic by request (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
struckn
post May 4 2016, 07:42 AM
If it's a Vented Battery, such as I have, buy a Battery Mat that will help control the vented Battery Acid that excapes. Cut the mat to size and put it under the Battery on the tray, and also cut a peace to go Vertically behind the battery. Replace it every couple years, it will nuetralize the acid.
914   914-4 Battery?   May 3 2016, 08:17 AM
Amphicar770   A lot of people use the Optima batteries. No worr...   May 3 2016, 08:49 AM
malcolm2   A lot of people use the Optima batteries. No wor...   May 3 2016, 09:11 AM
era vulgaris   [quote name='Amphicar770' post='2339580' date='Ma...   May 3 2016, 06:21 PM
1TRICK6   Bosch 96R battery fits perfect. Check PepBoys, usu...   May 3 2016, 09:13 AM
malcolm2   Something else I really like are my connectors. I...   May 3 2016, 09:22 AM
914   Thanks everyone for the reply's.I got the Bosc...   May 3 2016, 06:10 PM
porsche913b_sp   Thanks everyone for the reply's.I got the Bos...   May 3 2016, 08:16 PM
struckn   If it's a Vented Battery, such as I have, buy ...   May 4 2016, 07:42 AM
Drums66   If it's a Vented Battery, such as I have, buy...   Oct 10 2017, 01:41 PM
championgt1   Thanks everyone for the reply's.I got the Bo...   May 5 2016, 09:25 AM
914   Here is the Bosch battery..Again Thanks everyone f...   May 4 2016, 05:35 PM
Amphicar770   Here is the Bosch battery..Again Thanks everyone ...   May 5 2016, 08:24 AM
914   Always used a mat on my Four and Six.. 914   May 5 2016, 08:59 AM
JFG   Any chance you can post the dimendions of the bosc...   May 23 2016, 03:22 AM
dlkawashima   The battery purchased by the original poster is a ...   May 23 2016, 04:32 AM
1stworks   Here's what I did. http://www.914world.com/b...   May 23 2016, 06:59 AM
Cairo94507   When it comes time for a battery, it is going to b...   May 23 2016, 08:21 AM
dlkawashima   When it comes time for a battery, it is going to ...   May 23 2016, 09:53 AM
fslick   dlkawashima, do you run a size 34? Would really li...   Oct 9 2017, 01:58 PM
Philip W.   [quote name='Cairo94507' post='2349034' date='May...   Oct 10 2017, 07:38 AM
fslick   Dr. Phil -- if you do order the Bosch AGM from pep...   Oct 10 2017, 11:52 AM
Philip W.   Dr. Phil -- if you do order the Bosch AGM from pe...   Oct 10 2017, 11:56 AM
arne   I put a Miata U1R AGM in mine. Smaller, lighter, c...   Oct 9 2017, 04:22 PM
fslick   Cool! I think next go around I'll do AGM. ...   Oct 9 2017, 09:03 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter, ...   Nov 3 2017, 05:34 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter,...   Nov 6 2017, 09:16 AM
Coondog   RE: 914-4 Battery?   Oct 9 2017, 10:06 PM
Rand   It's a no-brainer to avoid lead-acid. :sick: T...   Oct 9 2017, 10:48 PM
gereed75   It is pretty common in the experimental aircraft w...   Oct 10 2017, 07:25 AM
arne   It is pretty common in the experimental aircraft ...   Oct 10 2017, 11:55 AM
malcolm2   It is pretty common in the experimental aircraft...   Oct 11 2017, 08:44 AM
mzalanka   [quote name='arne' post='2536236' date='Oct 10 20...   Oct 12 2017, 10:09 PM
porschetub   It is pretty common in the experimental aircraft ...   Oct 10 2017, 03:27 PM
ValcoOscar   Another option: 25% Off Online Orders of Select H...   Oct 11 2017, 08:52 AM
ThreeV8s   Another option: 25% Off Online Orders of Select ...   Oct 12 2017, 07:24 PM
ThreeV8s   Can anyone confirm if this "non-spillable...   Oct 29 2017, 05:02 AM
Elliot Cannon   I just found this tonight. http://www.batterymart...   Nov 6 2017, 10:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:31 PM
