era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
How much can one compensate for the other?
For example, with larger jets and idle screws further in, could you tune a set of carbs identically to another set of the same carbs that had smaller jets with the mix screw further out? I want to experiment with going a little leaner at idle and seeing how my engine likes it. I'm trying to decide if I should order a smaller set of idle jets or if I can achieve the same result by just turning the screws in further. Basically, what is the difference? Don't they achieve the same ends? Obviously there's a limit on the rich side because there's only so much fuel a jet will allow to flow. But if you're trying to lean it out, what's the difference between going to a smaller jet or just turning in the screw? |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
First answer, no, it does not work that way.
Then, no. Look into getting an exhaust gas temp sensor.....even used temporarily while you tune....it will still do the job. What you need to see is the temp of the exhaust where lean is hot and Rush is cool Rich |
Lo-Fi Version | Time is now: 9th July 2025 - 05:02 PM |
