> Accelerator Cable for Dual Carbs ?
cary
post May 8 2016, 07:55 AM
In putting Mark's engine back in and replacing the broken accelerator cable. It seems the cable isn't quite long enough to work/fit correctly. In the FI arrangement the cable crosses the engine at 45 degrees. In dual carbs it needs to come at the bar at 90 degrees. Which pulls the bowden out of the firewall. Which will allow water down the cable tube.
What have others done to work around this ?
Closed TopicStart new topic
Darren C
post May 10 2016, 01:25 AM
Region Association: England
Thanks for the kind comments.
I can understand your hope in making the CSP linkage you have “work to a fashion” which is a no cost option for you; but the title of the thread is accelerator cable related.
The fact of the matter is, the CSP linkage places the cable in line with the crankcase join, leading to having to re-route, bend and re-support the cable in an awkward way that will lead to length and binding issues. However “neat” you may think the CSP linkage initially looks, it isn’t a good product and will always have the inherent engineering faults that will cause issues.
As a very low cost compromise you could cut (hacksaw) off the short arm where the throttle cable connects, install the linkage and set the 45 Deg angle, adjust the rods to the carbs then weld the cut off short cable arm back on at a new angle in line with where the cable should run in a stock layout. You’ll need to make up a new small support bracket for the cable so that it can run at the natural angle it needs, to avoid all the issues.
RG,
The tangerine racing cable system is SHOCKING. Do you really think that that is good engineering??
Ok, you may go “ooooo” & ahhhhh” when you slap eyes on it, but really; its bloody stupid, over engineered and damn right dangerous.
Again your take off the Weber levers? Then fit pulley wheels with a counterbore in which to refit the lever retaining nut….so theres no provision then for the tab lock washer??
There is slotted brackets on which slotted brackets and eyebolts fit to hold the cable! This is BAD engineering and gives scope for the whole damn thing moving out of alignment.
You then link Carb A to B with a Bowden cable! So you are totally reliant upon Carb B’s return spring to keep the cable tension as well as return the throttle to idle when you lift off the gas pedal!!!
This in itself is plain stupid and dangerous as there is potential for not only imbalance in the control of the Twin carbs but also a chance that Carb B may stick open if the cable sticks or the return spring on Carb B breaks or weakens.
With age the Bowden cables will increase in resistance between the Carbs and to some minor extent suffer with heat expansion & contraction.
There is also a risk you run a cable off the pulley in a jam situation.
On rapid throttle operation the cable resistances will effect balanced “snap shut” responses between carbs. This will promote poor fuel balance and cause at best “popping” or at worst unwanted surge when you desire engine braking.
At least with a metal bar link rods you get positive shut off and proportional opening & closing between Carbs.
There is also the problem of running the accelerator cable to the first carb in this set up. The stock cable is either going to be too long or too short!
The whole Tangerine set up is intrinsically dangerous!
It’s a great example of “the emperors new clothes” engineering by someone without a clue of the big picture.
ThePaintedMan
post May 10 2016, 08:59 AM
QUOTE(Darren C @ May 10 2016, 03:25 AM) *
I'm not even sure why I bother responding to rants like this... but here it goes.
1) You're bashing the designs of a valued business member here, without much basis. I believe Chris has sold well over 100 of his linkages, and several of us have put them on race cars. Not one single failure thus far, as far as I know.
2) Like most people who feel that their opinion is the only one that counts, you have bashed two different designs, but as yet have not provided your own solution to the market. You know, the only "correct" linkage design. Congrats on being able to fab your own version, but unless you're selling it, I don't see why you're so angry.
3) Run a cable off the pulley in a jam situation? Oh, you mean like ALL modern throttle bodies before the manufacturers went to fly-by-wire? (IMG:style_emoticons/default/confused24.gif)
4) Chris's design does not only rely on Carb B's throttle return spring. If you took the time to understand it, both carbs still have their own return springs. I went ahead and added a second return spring to both as well out of my own choosing. But I never had any of the issues you describe before I did that.
5) The stock cable works fine. It is neither too long or too short.
Chill out. If you have no constructive criticism, or can't at least present it that way, then please just relax.
Darren C
post May 10 2016, 09:17 AM
QUOTE(ThePaintedMan @ May 10 2016, 03:59 PM) *
I'm not even sure why I bother responding to rants like this... but here is goes.
Like most heated replies to opinion, you fail to correctly read and understand my concise observations and retort at a tangent that is not constructive.
I fully understand the fact that I’m sticking my head above the parapet here by stating that all the commercially available carb conversion linkage kits for the 914 are flawed in one way or another.
However, I certainly don’t in anyway want to make this a personal attack on any individual. Again I understand that the guy’s who make and sell these kits have done it with all good intention.
Unfortunately I feel that they could be so much better, and in pointing out the flaws they may be taken onboard and resolved.
Little has changed since the 1960’s with the twin carb conversion kits. Empi etc must have sold 1000’s of the hex bar kits over the years. In the cold light of day we all know they’re not great, yet they still make them and folks will still buy them. The quantity sold is no indication that they're any good, just that they fill a gap in the market for which there's a demand.
This is a Forum…..and as such I’m just venting my frustration as an engineer at the worlds acceptance of a compromise when things could be made so much better, from which everyone would benefit.
I don’t know any of the vendors from Adam, and my observations and opinion is not an attack on the person, its on the flaws of their product. I have no intention of mass producing the utopic linkage or cable kit to compete with anyone, I just wish to vent my opinion and maybe let the manufacturers take some of it onboard and improve their products at best. At worst if a single person/owner says “Ah, I get what you say about this or that issue you’ve raised” I’ll be content. I’m not here for a fight just to maybe open others eyes to the complacent acceptance of these products and the fact the issues can be easily resolved to make a mediocre product great.
It's always a hard pill to swallow when some stranger says "Geez your baby's ugly"
cary   Accelerator Cable for Dual Carbs ?   May 8 2016, 07:55 AM
rfinegan   Take a look by the pedal cluster and the pivot for...   May 8 2016, 08:13 AM
somd914   Take a look by the pedal cluster and the pivot fo...   May 8 2016, 08:27 AM
rhodyguy   Is the linkage on the rear of the carbs?   May 8 2016, 08:35 AM
cary   Is the linkage on the rear of the carbs? I...   May 8 2016, 08:47 AM
cary   Cable itself is long enough. But when I use the ac...   May 8 2016, 08:36 AM
somd914   Cable itself is long enough. But when I use the a...   May 8 2016, 08:44 AM
cary   Cable itself is long enough. But when I use the ...   May 8 2016, 08:49 AM
rhodyguy   I don't recall the inner sheath sticking out t...   May 8 2016, 09:11 AM
cary   That ones in the garbage can. Busted and the barre...   May 8 2016, 09:16 AM
MarkV   My set up might be different because of the a/c co...   May 8 2016, 09:18 AM
cary   That's where it needs to come from. That will ...   May 8 2016, 09:22 AM
SA-914   This is what I have so far. But the pedal feels l...   May 8 2016, 09:59 AM
Darren C   WTF SA-914 That bellcrank linkage geometry is AL...   May 8 2016, 02:13 PM
somd914   Looks like SA914 is running a CSP linkage system. ...   May 8 2016, 07:06 PM
SA-914   Somd914-you got any pics of your installed system?...   May 8 2016, 09:32 PM
Darren C   From reading the installation manual somd914 kindl...   May 9 2016, 12:51 AM
somd914   I can post a few pics tonight. But for keeping it...   May 9 2016, 03:53 AM
Darren C   The KISS comment is aimed at CSP for bringing to m...   May 9 2016, 05:15 AM
somd914   The KISS comment is aimed at CSP for bringing to ...   May 9 2016, 05:35 PM
dcecc1968   When I switched to dual webers with hexbar and rep...   May 9 2016, 06:29 AM
cary   Dang, I didn't know that there was quite this...   May 9 2016, 07:09 AM
rgolia   Get the tangerine racing cable system...what a dif...   May 9 2016, 04:26 PM
SA-914   Got it. Just need to shorten my bracket to get it...   May 9 2016, 07:12 PM
Darren C   Thanks for the kind comments. I can understand you...   May 10 2016, 01:25 AM
ThePaintedMan   The tangerine racing cable system is SHOCKING. Do...   May 10 2016, 08:59 AM
Darren C   The tangerine racing cable system is SHOCKING. D...   May 10 2016, 09:17 AM
yeahmag   RG, The tangerine racing cable system is SHOCKIN...   May 12 2016, 03:21 PM
rhodyguy   If YOU can build a better mouse trap do so. Let it...   May 10 2016, 10:34 AM
rgolia   Well sorry I chimed in and thanks for defending Ch...   May 10 2016, 12:54 PM
Darren C   Ok, time out. George, Please change anger & ...   May 10 2016, 03:05 PM
Racer Chris   If any of the vendors visit this site or if any o...   May 12 2016, 03:46 PM
Darren C   If any of the vendors visit this site or if any ...   May 12 2016, 04:05 PM
ThePaintedMan   You're just too smart for the rest of us Darr...   May 12 2016, 05:00 PM
rgolia   Darren, All good here. I understand where you are...   May 10 2016, 03:30 PM
rhodyguy   So, your bluntness can be acceptable and explained...   May 10 2016, 04:04 PM
Darren C   So, your bluntness can be acceptable and explaine...   May 10 2016, 04:10 PM
rhodyguy   Of course! BUT, considering the other linkag...   May 10 2016, 04:16 PM
Darren C   I'll give you that one. But genetically you k...   May 10 2016, 04:22 PM
cary   Is it me, or is the bar style dual carb linkage pr...   May 10 2016, 06:12 PM
somd914   Is it me, or is the bar style dual carb linkage p...   May 10 2016, 06:37 PM
cary   I'll retract that statement/question. I didn...   May 10 2016, 08:21 PM
Darren C   Cary, Sometimes you have to go with your gut feeli...   May 12 2016, 05:44 AM
somd914   If anything I'd say the DD with FI has an is...   May 12 2016, 04:03 PM
Darren C   Ok Aaron, Lets look at what I wrote and what you ...   May 12 2016, 03:44 PM
rhodyguy   Muddied the fucking water? Dude, you tore the link...   May 12 2016, 04:28 PM
Darren C   Muddied the fucking water? Dude, you tore the lin...   May 12 2016, 04:35 PM
rhodyguy   Ok one more since you have now made personal. As o...   May 12 2016, 04:58 PM
Darren C   Ok one more since you have now made personal. As ...   May 12 2016, 11:26 PM
rhodyguy   Chum the waters. The sparkling lure flashes. Fish ...   May 13 2016, 07:06 AM
Darren C   You're gonna need a bigger boat.   May 13 2016, 07:35 AM
jd74914   ​Apologies for sticking my nose in here since I ...   May 13 2016, 08:19 AM
Darren C   Thanks jd, much appreciated. I waste a lot of my l...   May 13 2016, 02:06 PM
Scott S   "I also like to think that in some way also i...   May 13 2016, 03:51 PM
Darren C   Its going to "happen" when you don't...   May 13 2016, 04:34 PM
rhodyguy   :flag1: :brain: :bravo3d:   May 13 2016, 05:15 PM
Darren C   Exactly Rhodyguy, thanks.(Is that you cutting your...   May 14 2016, 06:10 AM
rhodyguy   :pissoff: :mueba: :splat:   May 14 2016, 06:32 AM
Darren C   You're trouble. I have your card marked Banana...   May 14 2016, 06:36 AM
rhodyguy   :idea: :unsure: :pissoff: ...   May 14 2016, 06:47 AM
somd914   I've been sitting on the sidelines after this ...   May 14 2016, 06:51 AM
rhodyguy   Egotistical novellas...BLOODY BRILLIANT!! ...   May 14 2016, 07:25 AM
bandjoey   Guys Guys Guys Guys Guys :Qarl: Cal...   May 14 2016, 09:17 AM
somd914   Guys Guys Guys Guys Guys :Qarl: Ca...   May 14 2016, 10:32 AM
Darren C   Somd914, I’m sorry you feel the thread was hi j...   May 14 2016, 01:17 PM
somd914   Darren, Fair enough, I appreciate your taking the...   May 14 2016, 02:44 PM
Darren C   Thanks Scott. On a lighter note... https://www.y...   May 15 2016, 01:19 AM
rhodyguy   Did you attend a public school?   May 15 2016, 08:16 AM
Darren C   Change of bait eh Banana-man? Maybe not so? Like ...   May 15 2016, 09:19 AM
rhodyguy   That would be mr powers to you. Or Kevin. How abou...   May 15 2016, 09:32 AM
Darren C   What...answer that either way just so you can make...   May 15 2016, 03:46 PM
SirAndy   :WTF: Thread closed ...   May 16 2016, 12:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
