> Pushrod, lifter, valve, etc. PROBLEM., Daily Driver emergency!
ripper911
post May 9 2016, 06:18 PM
corde pulsum tangite
I went to perform a valve adjustment and the exhaust valve on #4 wouldn't tighten. I got frustrated and called in a travelling 914 mechanic.
The screw was binding in the rocker, but he got it tightened enough to try to adjust. It wasn't moving while turning the engine. I was left with instructions to pull the rockers and check the pushrod as it might be bent. I pulled the pushed out, and it looks pretty straight to me, so he said to pull the lifter out with a magnet and inspect it. This is where I'm stuck.
I was having trouble with my extendable magnet extending and collapsing while trying to pull the lifter out. I bought some new magnets, but I'm still not having any luck. The mechanic said that it takes some finessing to get out. Is there a trick to it?
What makes it worse is that I have been using one of my boss's cars in the meantime, but they're selling the business (closing on sale Wednesday) so I need to give the car back.
I'll get the mechanic back over here soon, but going on my knowledge of the car, if the pushrod isn't bent, and if the lifter turns out to be OK, then it won't be something I can fix over the weekend.
Help... (IMG:style_emoticons/default/unsure.gif)
r_towle
post May 10 2016, 02:08 PM
Custom Member
You don't know what is wrong....
Might be cheaper, and quicker, to diagnose it, then hunt for parts.
ripper911   Pushrod, lifter, valve, etc. PROBLEM.   May 9 2016, 06:18 PM
Dave_Darling   No trick to it; just get the magnet down to the li...   May 9 2016, 07:57 PM
ripper911   The adjustment screw got buggered up. I'll ha...   May 9 2016, 08:43 PM
r_towle   They don't come out that easy....sometimes a r...   May 9 2016, 08:55 PM
ripper911   I'm supposed to pull the lifter to inspect it ...   May 9 2016, 09:06 PM
r_towle   Put it back together and don't worry about the...   May 9 2016, 09:52 PM
ripper911   IF the camshaft was wearing out, you would have ...   May 10 2016, 05:38 AM
Jake Raby   IF the camshaft was wearing out, you would have...   May 10 2016, 08:11 AM
r_towle   [quote name='ripper911' post='2342524' date='May ...   May 10 2016, 01:46 PM
ripper911   You gotta tell the whole story up front dude. R...   May 10 2016, 02:07 PM
Jake Raby   The lifter won't slide through the bore, for r...   May 9 2016, 10:02 PM
ripper911   The lifter won't slide through the bore, for ...   May 10 2016, 05:11 AM
stugray   Just curious: You are not trying to pull the lift...   May 9 2016, 10:10 PM
rjames   Just curious: You are not trying to pull the lif...   May 10 2016, 12:27 AM
ripper911   Just curious: You are not trying to pull the li...   May 10 2016, 05:03 AM
The Cabinetmaker   Stu said it right. You must pull the pushrod tube ...   May 10 2016, 06:01 AM
ripper911   Stu said it right. You must pull the pushrod tube...   May 10 2016, 06:11 AM
ripper911   So... Let's say that I NEED to have a car runn...   May 10 2016, 01:35 PM
stugray   So... Let's say that I NEED to have a car run...   May 10 2016, 01:40 PM
ripper911   So... Let's say that I NEED to have a car ru...   May 10 2016, 01:41 PM
r_towle   Used 1.8 head. Pull motor, swap head....a weekend ...   May 10 2016, 01:52 PM
r_towle   You don't know what is wrong.... Might be che...   May 10 2016, 02:08 PM
ripper911   Slight progress, but still rampant frustration. I...   May 11 2016, 10:51 AM
stugray   Another thing you can check now: Since the rocker ...   May 11 2016, 10:56 AM
veekry9   Tools in the box,a steel rule and an air adapter. ...   May 11 2016, 11:06 AM
ripper911   I should just toss my 911 engine in it.   May 11 2016, 11:13 AM
Dave_Darling   I should just toss my 911 engine in it. Yeah, b...   May 11 2016, 04:56 PM
veekry9   Yes you should,then install an LS7 into the 911...   May 11 2016, 12:04 PM
ripper911   Yes you should,then install an LS7 into the 91...   May 11 2016, 06:23 PM
ripper911   Luckily I'm getting a deal on a VW kit car tha...   May 11 2016, 06:19 PM
ripper911   Luckily I'm getting a deal on a VW kit car th...   May 11 2016, 06:31 PM
veekry9   To the moon,Alice. A glass SS100,in a mod shade,ma...   May 11 2016, 06:33 PM
ripper911   http://www.914world.com/bbs2/uploads_offsite/i921....   May 11 2016, 06:36 PM
ripper911   I'll fix the 914 eventually, I always do. :dr...   May 11 2016, 08:02 PM
r_towle   Looks like you.......might fit the skeleton better...   May 11 2016, 08:08 PM
ripper911   Looks like you.......might fit the skeleton bette...   May 11 2016, 08:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
