| cary |
May 8 2016, 07:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
In putting Mark's engine back in and replacing the broken accelerator cable. It seems the cable isn't quite long enough to work/fit correctly. In the FI arrangement the cable crosses the engine at 45 degrees. In dual carbs it needs to come at the bar at 90 degrees. Which pulls the bowden out of the firewall. Which will allow water down the cable tube.
What have others done to work around this ? |
| Darren C |
May 12 2016, 05:44 AM
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Cary,
Sometimes you have to go with your gut feeling. The DD is a good but not fallible reference. You need to consider several things in our 40+ year old cars. Starting at front. 1, The gas pedal. I’ve changed several of these over the years in my various 911’s and also in my 914 and got a whole new feel. The metal hinges inside the pedal rust and go stiff so can affect the resistance and feel. The hinges can also wear and even break inside the rubber and you wouldn’t necessarily know. The pedal design also relies in part to the rubber moulded around the hinge to act as a natural return to the upright position when you let your foot off. If you replace it, buy GENUINE Porsche, for a few dollars more you get a thicker steel inside and better quality hinge than the aftermarket copies. 2, Pedal set bushes. If worn these will cause issues in smooth operation and increased friction. 3, Cable route at the pedal end and chassis tube. It is possible to cross over the accelerator & clutch cables inadvertently when replacing them so one runs across another. You can’t see easily inside the tunnel and this can happen especially if the accelerator cable tube breaks free at the pedal end. Corrosion is an issue here as it causes friction and closes down on the cable if the tube is rusty. 4, Cable. ALL cables wear. Most owners carryout a Carb conversion and use their old accelerator cable thinking it’s ok. Bowden cables wear the nylon sheath on the inside radius of any bend and the outside radius at each end of any bend and cable outlet from each end of a sheath. Over time if a cable is undisturbed you don’t really feel any difference as you get used to it and the change is so infinitely small. It only becomes an issue if the nylon sheath breaks somewhere (usually where the steel ferrule fits at the bulkhead) wears through, the cable sheds a wire or jams and the sheath external spring rusts out. Cables also pick up dirt and dust and fray which can give resistance. I've had cables out of a car and they run free (making you think they're fine) refitted them and they bind under operational tension or when asked to lay in awkward routes. The worst thing owners can do is oil these accelerator cables in good faith. This can swell the sheath, attract dust/dirt to quickly clog up and although you think you've solved an issue temporarily, long term its just made things worse. The cable is a cheap item (in Porsche terms) and easy to replace, so if you're unsure how old your cable is and what condition it's in...just change it for peace of mind. When owners carryout a FI to carb conversion, one big issue is moving an old cable around the engine bay to the new linkage mounting point. Just doing this itself can create a binding as the old worn cable is now bending/laying in a different position so any internal wear from where its “worn in and settled” over the years can be an issue Cary, its difficult to have a good reference unless your reference is a car with all new parts down the chain. If you jumped in the car and thought “hey this pedal feels stiff” then 9 times out of 10 I’d say go with your gut feeling. Comparing it to an “unknown quantity” another DD is a starting point but certainly not to be relied upon. Looking at it logically, on FI you have only one throttle body, one butterfly valve and 2 springs (dependent on year, there’s a coil on the shaft and a secondary emergency spring introduced a little later). On a carb conversion you have 2 spindle, 4 throttle butterflies, two coil springs, and additional springs that come with your linkage, and maybe more springs owners have added to get the throttles to return. Plus most linkages have friction points and odd mechanical advantages thrown into the equation. It’s for this reason that I’d question your comparison with the DD against your gut feeling here. If anything I'd say the DD with FI has an issue if its got the same heavy pedal feel/resistance as the carb conversion car! Regards Darren |
cary Accelerator Cable for Dual Carbs ? May 8 2016, 07:55 AM
rfinegan Take a look by the pedal cluster and the pivot for... May 8 2016, 08:13 AM
somd914
Take a look by the pedal cluster and the pivot fo... May 8 2016, 08:27 AM
rhodyguy Is the linkage on the rear of the carbs? May 8 2016, 08:35 AM
cary
I... May 8 2016, 08:47 AM
cary Cable itself is long enough. But when I use the ac... May 8 2016, 08:36 AM
somd914
Cable itself is long enough. But when I use the a... May 8 2016, 08:44 AM
cary
Cable itself is long enough. But when I use the ... May 8 2016, 08:49 AM
rhodyguy I don't recall the inner sheath sticking out t... May 8 2016, 09:11 AM
cary That ones in the garbage can. Busted and the barre... May 8 2016, 09:16 AM
MarkV My set up might be different because of the a/c co... May 8 2016, 09:18 AM
cary That's where it needs to come from. That will ... May 8 2016, 09:22 AM
SA-914 This is what I have so far. But the pedal feels l... May 8 2016, 09:59 AM
Darren C WTF
SA-914 That bellcrank linkage geometry is AL... May 8 2016, 02:13 PM
somd914 Looks like SA914 is running a CSP linkage system. ... May 8 2016, 07:06 PM
SA-914 Somd914-you got any pics of your installed system?... May 8 2016, 09:32 PM
Darren C From reading the installation manual somd914 kindl... May 9 2016, 12:51 AM
somd914 I can post a few pics tonight.
But for keeping it... May 9 2016, 03:53 AM
Darren C The KISS comment is aimed at CSP for bringing to m... May 9 2016, 05:15 AM
somd914
The KISS comment is aimed at CSP for bringing to ... May 9 2016, 05:35 PM
dcecc1968 When I switched to dual webers with hexbar and rep... May 9 2016, 06:29 AM
cary Dang, I didn't know that there was quite this... May 9 2016, 07:09 AM
rgolia Get the tangerine racing cable system...what a dif... May 9 2016, 04:26 PM
SA-914 Got it. Just need to shorten my bracket to get it... May 9 2016, 07:12 PM
Darren C Thanks for the kind comments.
I can understand you... May 10 2016, 01:25 AM
ThePaintedMan
The tangerine racing cable system is SHOCKING. Do... May 10 2016, 08:59 AM
Darren C
The tangerine racing cable system is SHOCKING. D... May 10 2016, 09:17 AM
yeahmag
RG,
The tangerine racing cable system is SHOCKIN... May 12 2016, 03:21 PM
rhodyguy If YOU can build a better mouse trap do so. Let it... May 10 2016, 10:34 AM
rgolia Well sorry I chimed in and thanks for defending Ch... May 10 2016, 12:54 PM
Darren C Ok, time out.
George,
Please change anger & ... May 10 2016, 03:05 PM
Racer Chris
If any of the vendors visit this site or if any o... May 12 2016, 03:46 PM
Darren C
If any of the vendors visit this site or if any ... May 12 2016, 04:05 PM
ThePaintedMan
You're just too smart for the rest of us Darr... May 12 2016, 05:00 PM
rgolia Darren,
All good here. I understand where you are... May 10 2016, 03:30 PM
rhodyguy So, your bluntness can be acceptable and explained... May 10 2016, 04:04 PM
Darren C
So, your bluntness can be acceptable and explaine... May 10 2016, 04:10 PM
rhodyguy Of course!
BUT, considering the other linkag... May 10 2016, 04:16 PM
Darren C I'll give you that one.
But genetically you k... May 10 2016, 04:22 PM
cary Is it me, or is the bar style dual carb linkage pr... May 10 2016, 06:12 PM
somd914
Is it me, or is the bar style dual carb linkage p... May 10 2016, 06:37 PM
cary I'll retract that statement/question. I didn... May 10 2016, 08:21 PM
somd914
If anything I'd say the DD with FI has an is... May 12 2016, 04:03 PM
Darren C Ok Aaron,
Lets look at what I wrote and what you ... May 12 2016, 03:44 PM
rhodyguy Muddied the fucking water? Dude, you tore the link... May 12 2016, 04:28 PM
Darren C
Muddied the fucking water? Dude, you tore the lin... May 12 2016, 04:35 PM
rhodyguy Ok one more since you have now made personal. As o... May 12 2016, 04:58 PM
Darren C
Ok one more since you have now made personal. As ... May 12 2016, 11:26 PM
rhodyguy Chum the waters. The sparkling lure flashes. Fish ... May 13 2016, 07:06 AM
Darren C You're gonna need a bigger boat. May 13 2016, 07:35 AM
jd74914 Apologies for sticking my nose in here since I ... May 13 2016, 08:19 AM
Darren C Thanks jd, much appreciated. I waste a lot of my l... May 13 2016, 02:06 PM
Scott S "I also like to think that in some way also i... May 13 2016, 03:51 PM
Darren C Its going to "happen" when you don't... May 13 2016, 04:34 PM
rhodyguy :flag1: :brain: :bravo3d: May 13 2016, 05:15 PM
Darren C Exactly Rhodyguy, thanks.(Is that you cutting your... May 14 2016, 06:10 AM
rhodyguy :pissoff: :mueba: :splat: May 14 2016, 06:32 AM
Darren C You're trouble. I have your card marked Banana... May 14 2016, 06:36 AM
rhodyguy :idea: :unsure: :pissoff: ... May 14 2016, 06:47 AM
somd914 I've been sitting on the sidelines after this ... May 14 2016, 06:51 AM
rhodyguy Egotistical novellas...BLOODY BRILLIANT!! ... May 14 2016, 07:25 AM
bandjoey Guys Guys Guys Guys Guys :Qarl:
Cal... May 14 2016, 09:17 AM
somd914
Ca... May 14 2016, 10:32 AM
Darren C Somd914,
I’m sorry you feel the thread was hi j... May 14 2016, 01:17 PM
somd914 Darren,
Fair enough, I appreciate your taking the... May 14 2016, 02:44 PM
Darren C Thanks Scott.
On a lighter note...
https://www.y... May 15 2016, 01:19 AM
rhodyguy Did you attend a public school? May 15 2016, 08:16 AM
Darren C Change of bait eh Banana-man? Maybe not so?
Like ... May 15 2016, 09:19 AM
rhodyguy That would be mr powers to you. Or Kevin. How abou... May 15 2016, 09:32 AM
Darren C What...answer that either way just so you can make... May 15 2016, 03:46 PM
SirAndy :WTF: Thread closed ... May 16 2016, 12:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:13 AM |
