> Accelerator Cable for Dual Carbs ?
cary
post May 8 2016, 07:55 AM
In putting Mark's engine back in and replacing the broken accelerator cable. It seems the cable isn't quite long enough to work/fit correctly. In the FI arrangement the cable crosses the engine at 45 degrees. In dual carbs it needs to come at the bar at 90 degrees. Which pulls the bowden out of the firewall. Which will allow water down the cable tube.
What have others done to work around this ?
Closed TopicStart new topic
rhodyguy
post May 12 2016, 04:28 PM
Muddied the fucking water? Dude, you tore the linkage up! Let us see...."bloody stupid" (tally ho!), "over engineered", "damn right dangerous", next "plain stupid" ( make up your mind!) and then dangerous again. Have you forgotten what you have written? My cable goes thu the tin, with a grommet, where it is supposed to, stays where it's supposed to at the firewall and operates nicely. My last entry on this one. One wonderful thing about the British (IMHO) is you can tell them to fuck off and nobody breaks a sweat. Calling someone a cunt works for both genders and as a general rule is no foul. There you have it....bob's your uncle.
cary   Accelerator Cable for Dual Carbs ?   May 8 2016, 07:55 AM
rfinegan   Take a look by the pedal cluster and the pivot for...   May 8 2016, 08:13 AM
somd914   Take a look by the pedal cluster and the pivot fo...   May 8 2016, 08:27 AM
rhodyguy   Is the linkage on the rear of the carbs?   May 8 2016, 08:35 AM
cary   Is the linkage on the rear of the carbs? I...   May 8 2016, 08:47 AM
cary   Cable itself is long enough. But when I use the ac...   May 8 2016, 08:36 AM
somd914   Cable itself is long enough. But when I use the a...   May 8 2016, 08:44 AM
cary   Cable itself is long enough. But when I use the ...   May 8 2016, 08:49 AM
rhodyguy   I don't recall the inner sheath sticking out t...   May 8 2016, 09:11 AM
cary   That ones in the garbage can. Busted and the barre...   May 8 2016, 09:16 AM
MarkV   My set up might be different because of the a/c co...   May 8 2016, 09:18 AM
cary   That's where it needs to come from. That will ...   May 8 2016, 09:22 AM
SA-914   This is what I have so far. But the pedal feels l...   May 8 2016, 09:59 AM
Darren C   WTF SA-914 That bellcrank linkage geometry is AL...   May 8 2016, 02:13 PM
somd914   Looks like SA914 is running a CSP linkage system. ...   May 8 2016, 07:06 PM
SA-914   Somd914-you got any pics of your installed system?...   May 8 2016, 09:32 PM
Darren C   From reading the installation manual somd914 kindl...   May 9 2016, 12:51 AM
somd914   I can post a few pics tonight. But for keeping it...   May 9 2016, 03:53 AM
Darren C   The KISS comment is aimed at CSP for bringing to m...   May 9 2016, 05:15 AM
somd914   The KISS comment is aimed at CSP for bringing to ...   May 9 2016, 05:35 PM
dcecc1968   When I switched to dual webers with hexbar and rep...   May 9 2016, 06:29 AM
cary   Dang, I didn't know that there was quite this...   May 9 2016, 07:09 AM
rgolia   Get the tangerine racing cable system...what a dif...   May 9 2016, 04:26 PM
SA-914   Got it. Just need to shorten my bracket to get it...   May 9 2016, 07:12 PM
Darren C   Thanks for the kind comments. I can understand you...   May 10 2016, 01:25 AM
ThePaintedMan   The tangerine racing cable system is SHOCKING. Do...   May 10 2016, 08:59 AM
Darren C   The tangerine racing cable system is SHOCKING. D...   May 10 2016, 09:17 AM
yeahmag   RG, The tangerine racing cable system is SHOCKIN...   May 12 2016, 03:21 PM
rhodyguy   If YOU can build a better mouse trap do so. Let it...   May 10 2016, 10:34 AM
rgolia   Well sorry I chimed in and thanks for defending Ch...   May 10 2016, 12:54 PM
Darren C   Ok, time out. George, Please change anger & ...   May 10 2016, 03:05 PM
Racer Chris   If any of the vendors visit this site or if any o...   May 12 2016, 03:46 PM
Darren C   If any of the vendors visit this site or if any ...   May 12 2016, 04:05 PM
ThePaintedMan   You're just too smart for the rest of us Darr...   May 12 2016, 05:00 PM
rgolia   Darren, All good here. I understand where you are...   May 10 2016, 03:30 PM
rhodyguy   So, your bluntness can be acceptable and explained...   May 10 2016, 04:04 PM
Darren C   So, your bluntness can be acceptable and explaine...   May 10 2016, 04:10 PM
rhodyguy   Of course! BUT, considering the other linkag...   May 10 2016, 04:16 PM
Darren C   I'll give you that one. But genetically you k...   May 10 2016, 04:22 PM
cary   Is it me, or is the bar style dual carb linkage pr...   May 10 2016, 06:12 PM
somd914   Is it me, or is the bar style dual carb linkage p...   May 10 2016, 06:37 PM
cary   I'll retract that statement/question. I didn...   May 10 2016, 08:21 PM
Darren C   Cary, Sometimes you have to go with your gut feeli...   May 12 2016, 05:44 AM
somd914   If anything I'd say the DD with FI has an is...   May 12 2016, 04:03 PM
Darren C   Ok Aaron, Lets look at what I wrote and what you ...   May 12 2016, 03:44 PM
rhodyguy   Muddied the fucking water? Dude, you tore the link...   May 12 2016, 04:28 PM
Darren C   Muddied the fucking water? Dude, you tore the lin...   May 12 2016, 04:35 PM
rhodyguy   Ok one more since you have now made personal. As o...   May 12 2016, 04:58 PM
Darren C   Ok one more since you have now made personal. As ...   May 12 2016, 11:26 PM
rhodyguy   Chum the waters. The sparkling lure flashes. Fish ...   May 13 2016, 07:06 AM
Darren C   You're gonna need a bigger boat.   May 13 2016, 07:35 AM
jd74914   ​Apologies for sticking my nose in here since I ...   May 13 2016, 08:19 AM
Darren C   Thanks jd, much appreciated. I waste a lot of my l...   May 13 2016, 02:06 PM
Scott S   "I also like to think that in some way also i...   May 13 2016, 03:51 PM
Darren C   Its going to "happen" when you don't...   May 13 2016, 04:34 PM
rhodyguy   :flag1: :brain: :bravo3d:   May 13 2016, 05:15 PM
Darren C   Exactly Rhodyguy, thanks.(Is that you cutting your...   May 14 2016, 06:10 AM
rhodyguy   :pissoff: :mueba: :splat:   May 14 2016, 06:32 AM
Darren C   You're trouble. I have your card marked Banana...   May 14 2016, 06:36 AM
rhodyguy   :idea: :unsure: :pissoff: ...   May 14 2016, 06:47 AM
somd914   I've been sitting on the sidelines after this ...   May 14 2016, 06:51 AM
rhodyguy   Egotistical novellas...BLOODY BRILLIANT!! ...   May 14 2016, 07:25 AM
bandjoey   Guys Guys Guys Guys Guys :Qarl: Cal...   May 14 2016, 09:17 AM
somd914   Guys Guys Guys Guys Guys :Qarl: Ca...   May 14 2016, 10:32 AM
Darren C   Somd914, I’m sorry you feel the thread was hi j...   May 14 2016, 01:17 PM
somd914   Darren, Fair enough, I appreciate your taking the...   May 14 2016, 02:44 PM
Darren C   Thanks Scott. On a lighter note... https://www.y...   May 15 2016, 01:19 AM
rhodyguy   Did you attend a public school?   May 15 2016, 08:16 AM
Darren C   Change of bait eh Banana-man? Maybe not so? Like ...   May 15 2016, 09:19 AM
rhodyguy   That would be mr powers to you. Or Kevin. How abou...   May 15 2016, 09:32 AM
Darren C   What...answer that either way just so you can make...   May 15 2016, 03:46 PM
SirAndy   :WTF: Thread closed ...   May 16 2016, 12:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
