Loose Rear Wheel Bearing |
MarkV |
May 12 2016, 05:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I had a noise coming from the rear of my car that sounded like something was loose clanking around in my trunk of something. When I would go over bumps something was rattling around. I looked all over the exhaust system and checked the CV joints and couldn't find anything loose. I even emptied everything out of the trunk including the jack. I jacked the car up and noticed that my passenger side rear wheel was loose...it had like 3/8" of play when I pulled on it from side to side. So I ordered a new SFK rear bearing and installed it. After installing the bearing there is still some play in it. Not like it was but I can still hear something loose just not as much. The driver side bearing I changed a few years ago is tight with no play. I remember that when I changed the passenger side there were marks on the retainer where it looked like the outside radius on the bearing had spun at some point....didn't pay much attention to it. I have ordered another bearing and I am getting ready to take it apart again. Has anyone ever had a problem like this with a rear bearing...any pointers?
(IMG:style_emoticons/default/WTF.gif) |
Garland |
May 12 2016, 06:49 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
The rear bearings I installed, but have not run on yet, also have more play then I recall having, when I have installed them in the past.
The question I have is, how much play is there in a correctly installed rear wheel bearing? |
Lo-Fi Version | Time is now: 10th June 2024 - 01:18 AM |
