Loose Rear Wheel Bearing |
MarkV |
May 12 2016, 05:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I had a noise coming from the rear of my car that sounded like something was loose clanking around in my trunk of something. When I would go over bumps something was rattling around. I looked all over the exhaust system and checked the CV joints and couldn't find anything loose. I even emptied everything out of the trunk including the jack. I jacked the car up and noticed that my passenger side rear wheel was loose...it had like 3/8" of play when I pulled on it from side to side. So I ordered a new SFK rear bearing and installed it. After installing the bearing there is still some play in it. Not like it was but I can still hear something loose just not as much. The driver side bearing I changed a few years ago is tight with no play. I remember that when I changed the passenger side there were marks on the retainer where it looked like the outside radius on the bearing had spun at some point....didn't pay much attention to it. I have ordered another bearing and I am getting ready to take it apart again. Has anyone ever had a problem like this with a rear bearing...any pointers?
(IMG:style_emoticons/default/WTF.gif) |
MarkV |
May 12 2016, 07:07 PM
I had to use MAP gas to get the castle nut loose. I thought the bearing was original but it was a FAG made in Spain so maybe not. After I cleaned everything up the new bearing went in fairly east using the frozen bearing method. I did have to tap on the brake flange a couple of times with a block of wood to get enough thread to catch the castle nut. I used a torque wrench on the flange bolts and the CV bolts. I tightened the castle nut with a 1/2" air impact. Maybe I damaged the new bearing somehow....didn't seem like it at the time.
somd914 |
May 12 2016, 08:09 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I tightened the castle nut with a 1/2" air impact. Maybe I damaged the new bearing somehow....didn't seem like it at the time. But have you torqued it to required spec which I don't recall the value off the top of my head but recall it's in the 225-250 lb-ft. Unless you have a quality, heavy duty impact wrench, it won't get near that torque despite it's advertised numbers. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:46 AM |
