Loose Rear Wheel Bearing |
MarkV |
May 12 2016, 05:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I had a noise coming from the rear of my car that sounded like something was loose clanking around in my trunk of something. When I would go over bumps something was rattling around. I looked all over the exhaust system and checked the CV joints and couldn't find anything loose. I even emptied everything out of the trunk including the jack. I jacked the car up and noticed that my passenger side rear wheel was loose...it had like 3/8" of play when I pulled on it from side to side. So I ordered a new SFK rear bearing and installed it. After installing the bearing there is still some play in it. Not like it was but I can still hear something loose just not as much. The driver side bearing I changed a few years ago is tight with no play. I remember that when I changed the passenger side there were marks on the retainer where it looked like the outside radius on the bearing had spun at some point....didn't pay much attention to it. I have ordered another bearing and I am getting ready to take it apart again. Has anyone ever had a problem like this with a rear bearing...any pointers?
(IMG:style_emoticons/default/WTF.gif) |
ThePaintedMan |
May 12 2016, 08:47 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Well it *looks* like the bearing is fully seated in the arm, but it's possible you're not getting it fully seated. That bearing retainer should be completely flush if you've got it in all the way. If not, it could contribute to the issue you're seeing. I fully admit that I torqued down a hub nut on my wife's Mazda once to spec... but it kept growling when going down the road. Sure enough I never got the bearing in all the way - but like I said, it torqued to spec when the wheel was on the ground. Took it back off and sure enough, the bearing went in another 1/16th inch. Then torqued it down and all good. My mistake.
Still need to test to rule out the bushings too though. While you're in there sort of thing. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:43 PM |
