Loose Rear Wheel Bearing |
MarkV |
May 12 2016, 05:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I had a noise coming from the rear of my car that sounded like something was loose clanking around in my trunk of something. When I would go over bumps something was rattling around. I looked all over the exhaust system and checked the CV joints and couldn't find anything loose. I even emptied everything out of the trunk including the jack. I jacked the car up and noticed that my passenger side rear wheel was loose...it had like 3/8" of play when I pulled on it from side to side. So I ordered a new SFK rear bearing and installed it. After installing the bearing there is still some play in it. Not like it was but I can still hear something loose just not as much. The driver side bearing I changed a few years ago is tight with no play. I remember that when I changed the passenger side there were marks on the retainer where it looked like the outside radius on the bearing had spun at some point....didn't pay much attention to it. I have ordered another bearing and I am getting ready to take it apart again. Has anyone ever had a problem like this with a rear bearing...any pointers?
(IMG:style_emoticons/default/WTF.gif) |
MarkV |
May 13 2016, 10:09 AM
It still isn't as tight as the other side. I can still move it and it is not coming from the bushings so I decided to take it apart. It all came apart pretty easy and I don't believe I did any harm to the new bearing. I think I found the problem. The retainer plate is deformed. Not sure what would cause that to happen. Maybe the previous owner used it the draw down the bearing or something. Rather than try to source another retainer I am going to straighten the old one and run it over a belt sander to make sure it is flat. If it doesn't work I have another bearing and I can take it apart again and replace the retainer plate. (IMG:style_emoticons/default/smash.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:55 AM |
