Loose Rear Wheel Bearing |
MarkV |
May 12 2016, 05:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I had a noise coming from the rear of my car that sounded like something was loose clanking around in my trunk of something. When I would go over bumps something was rattling around. I looked all over the exhaust system and checked the CV joints and couldn't find anything loose. I even emptied everything out of the trunk including the jack. I jacked the car up and noticed that my passenger side rear wheel was loose...it had like 3/8" of play when I pulled on it from side to side. So I ordered a new SFK rear bearing and installed it. After installing the bearing there is still some play in it. Not like it was but I can still hear something loose just not as much. The driver side bearing I changed a few years ago is tight with no play. I remember that when I changed the passenger side there were marks on the retainer where it looked like the outside radius on the bearing had spun at some point....didn't pay much attention to it. I have ordered another bearing and I am getting ready to take it apart again. Has anyone ever had a problem like this with a rear bearing...any pointers?
(IMG:style_emoticons/default/WTF.gif) |
MarkV |
May 13 2016, 03:50 PM
I had to use a 3# slide hammer to get the old new bearing out. When I initially installed the SFK bearing the original bearing was really hard to get out. I don't beleive I had a loose bearing. After I flattened out the retainer and filed it I put it back on and torqued the bolts to 25#. When I took it back off you could see a mark all the way around it where it touched the outer circumference of the bearing. I believe the bearing stands proud of the trailing arm just a hair by design. Someone had over tightened the retainer at some point and deformed it. I think it is all good now no more play when I try to move the tire in and out.
Lo-Fi Version | Time is now: 10th June 2024 - 12:49 PM |
