| cary |
May 8 2016, 07:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
In putting Mark's engine back in and replacing the broken accelerator cable. It seems the cable isn't quite long enough to work/fit correctly. In the FI arrangement the cable crosses the engine at 45 degrees. In dual carbs it needs to come at the bar at 90 degrees. Which pulls the bowden out of the firewall. Which will allow water down the cable tube.
What have others done to work around this ? |
| Darren C |
May 14 2016, 01:17 PM
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Somd914,
I’m sorry you feel the thread was hi jacked and turned into a white paper on linkages. That wasn’t my intent at all. It was driven that way by persistent pressure on me to justify myself, my comments and experience. Granted I came over the hill from nowhere into this thread and vocally listed the deficiencies in the linkages on the market, in the viewpoint of an engineer. I fully accept initially that the majority who posted took offence at this. My intent was to be helpful. (Ok tin hat on here again for the retort) buried in this thread is some good information despite the flack. Cary’s OP was… “In putting Mark's engine back in and replacing the broken accelerator cable. It seems the cable isn't quite long enough to work/fit correctly. In the FI arrangement the cable crosses the engine at 45 degrees. In dual carbs it needs to come at the bar at 90 degrees. Which pulls the bowden out of the firewall. Which will allow water down the cable tube. What have others done to work around this ?” Cary asked “What have others done to work around this ?” Well I came in after several pictures had been posted by others showing their set ups, and SA-914 was having problems too. “This is what I have so far. But the pedal feels like it's in a bind.” said SA-914 I’d had exactly the same experiences with Type IV engines in the past and recently on my 914 where I had tried two types of suppliers linkages and knew straight away from his picture that SA-914 had an alignment set up issue. I could also see that the cable connection on his linkage was made for a cable set at 90 degrees not 45 degrees which is what Cary had expressed issues with on his very first post. In my first post I came in (albeit heavy as you perceive) but posted a link (that I'd taken 2 hours out of my day to write) to show SA-914 how I’d overcome this and a drawing I’d made showing him where his linkage was set in his photo and where it should be. I also posted a whole list on cable running issues including solutions for both Cary and SA-914 Somd914 you say… “Darren, sorry, you contributed nothing but destructive criticism and egotistical novellas” and repeat…” My point is that this thread was not about linkage design enhancements it was about helping those in requesting assistance with what they have, known systems that work.” I kinda don’t know how to answer the statement you’ve made Somd914, maybe you got hung up in the perceived personal lambasting that was going on? I don't know, so I’ll leave it with what I said above as it will otherwise keep going around in circles which Rhodyguy seems to want. Again you think I also shredded Chris without cause? I didn’t shred anyone or their reputation just the linkage, I didn’t know it was even a guy called Chris who made it when I posted (remember I am a relative newbie on here and 8000 miles away from the majority of you guy's). This is where I think people have taken offence and the thread has ended up running away at a tangent. You also say.. "Being an engineer and a team lead for many years. I've seen personalities like this tear apart many good engineering teams". Then I am afraid to tell you that it's a failure of the team leader and above them the team manager in both their abilities to lead or manage individuals, not the personality clashes in the team that needs improvement. I find that some of the most opinionated individuals are the best team performers if you manage them correctly. Equally you need to encourage and motivate those who wouldn't say boo to a goose, to express their opinions. (As you didn't specifically state the leader was you, my response is not aimed at you or intended to offend you) Bandjoey, Thanks for seeing some of my perspective here. 'Look at all the various methods, and pick the one you like' you say. I agree, totally and had said before you… “Look at ALL (not just one suppliers) 914 carb linkage kits, cable routes and general engineering quality and decide which one is for you” I’d love to show my car collection but as on most occasions in the past you get too many envious guys taking offence and a pop at you just because of what you have, not how you got it. But if ever you’re over here in UK, call me, we can take a day off and walk around, talk cars and maybe drive a few of your choice. Funny enough before logging on this evening to see if the embers had died down, I washed the 14 after going out racing at Goodwood with my good friend Nick Faure, British Motor Racing driver and Porsche enthusiast. We had a great day catching up on old times and while tearing the arse out of his very first pre-production Works 968 CS it was very luckily on a quick fluids check to notice the timing belt was fraying. So to avoid costly failure the car was recovered back to our mutual friends garage where I helped off load while Nick admired my 914. Bananaman, I’m quite a newbie here myself, venturing out of my Build off-challenge thread into other area’s of this forum. Granted I have strong opinions, this has certainly been an interesting experience; but if any single contributor to this thread has been unhelpful, abusive and personal while continuing to perpetuate the hate and bait, it has to be you. Just my observation of course..plus my Bananaman model is less crude, rude and much better engineered than yours by the way. :- ) Love and peace, love and peace |
cary Accelerator Cable for Dual Carbs ? May 8 2016, 07:55 AM
rfinegan Take a look by the pedal cluster and the pivot for... May 8 2016, 08:13 AM
somd914
Take a look by the pedal cluster and the pivot fo... May 8 2016, 08:27 AM
rhodyguy Is the linkage on the rear of the carbs? May 8 2016, 08:35 AM
cary
I... May 8 2016, 08:47 AM
cary Cable itself is long enough. But when I use the ac... May 8 2016, 08:36 AM
somd914
Cable itself is long enough. But when I use the a... May 8 2016, 08:44 AM
cary
Cable itself is long enough. But when I use the ... May 8 2016, 08:49 AM
rhodyguy I don't recall the inner sheath sticking out t... May 8 2016, 09:11 AM
cary That ones in the garbage can. Busted and the barre... May 8 2016, 09:16 AM
MarkV My set up might be different because of the a/c co... May 8 2016, 09:18 AM
cary That's where it needs to come from. That will ... May 8 2016, 09:22 AM
SA-914 This is what I have so far. But the pedal feels l... May 8 2016, 09:59 AM
Darren C WTF
SA-914 That bellcrank linkage geometry is AL... May 8 2016, 02:13 PM
somd914 Looks like SA914 is running a CSP linkage system. ... May 8 2016, 07:06 PM
SA-914 Somd914-you got any pics of your installed system?... May 8 2016, 09:32 PM
Darren C From reading the installation manual somd914 kindl... May 9 2016, 12:51 AM
somd914 I can post a few pics tonight.
But for keeping it... May 9 2016, 03:53 AM
Darren C The KISS comment is aimed at CSP for bringing to m... May 9 2016, 05:15 AM
somd914
The KISS comment is aimed at CSP for bringing to ... May 9 2016, 05:35 PM
dcecc1968 When I switched to dual webers with hexbar and rep... May 9 2016, 06:29 AM
cary Dang, I didn't know that there was quite this... May 9 2016, 07:09 AM
rgolia Get the tangerine racing cable system...what a dif... May 9 2016, 04:26 PM
SA-914 Got it. Just need to shorten my bracket to get it... May 9 2016, 07:12 PM
Darren C Thanks for the kind comments.
I can understand you... May 10 2016, 01:25 AM
ThePaintedMan
The tangerine racing cable system is SHOCKING. Do... May 10 2016, 08:59 AM
Darren C
The tangerine racing cable system is SHOCKING. D... May 10 2016, 09:17 AM
yeahmag
RG,
The tangerine racing cable system is SHOCKIN... May 12 2016, 03:21 PM
rhodyguy If YOU can build a better mouse trap do so. Let it... May 10 2016, 10:34 AM
rgolia Well sorry I chimed in and thanks for defending Ch... May 10 2016, 12:54 PM
Darren C Ok, time out.
George,
Please change anger & ... May 10 2016, 03:05 PM
Racer Chris
If any of the vendors visit this site or if any o... May 12 2016, 03:46 PM
Darren C
If any of the vendors visit this site or if any ... May 12 2016, 04:05 PM
ThePaintedMan
You're just too smart for the rest of us Darr... May 12 2016, 05:00 PM
rgolia Darren,
All good here. I understand where you are... May 10 2016, 03:30 PM
rhodyguy So, your bluntness can be acceptable and explained... May 10 2016, 04:04 PM
Darren C
So, your bluntness can be acceptable and explaine... May 10 2016, 04:10 PM
rhodyguy Of course!
BUT, considering the other linkag... May 10 2016, 04:16 PM
Darren C I'll give you that one.
But genetically you k... May 10 2016, 04:22 PM
cary Is it me, or is the bar style dual carb linkage pr... May 10 2016, 06:12 PM
somd914
Is it me, or is the bar style dual carb linkage p... May 10 2016, 06:37 PM
cary I'll retract that statement/question. I didn... May 10 2016, 08:21 PM
Darren C Cary,
Sometimes you have to go with your gut feeli... May 12 2016, 05:44 AM
somd914
If anything I'd say the DD with FI has an is... May 12 2016, 04:03 PM
Darren C Ok Aaron,
Lets look at what I wrote and what you ... May 12 2016, 03:44 PM
rhodyguy Muddied the fucking water? Dude, you tore the link... May 12 2016, 04:28 PM
Darren C
Muddied the fucking water? Dude, you tore the lin... May 12 2016, 04:35 PM
rhodyguy Ok one more since you have now made personal. As o... May 12 2016, 04:58 PM
Darren C
Ok one more since you have now made personal. As ... May 12 2016, 11:26 PM
rhodyguy Chum the waters. The sparkling lure flashes. Fish ... May 13 2016, 07:06 AM
Darren C You're gonna need a bigger boat. May 13 2016, 07:35 AM
jd74914 Apologies for sticking my nose in here since I ... May 13 2016, 08:19 AM
Darren C Thanks jd, much appreciated. I waste a lot of my l... May 13 2016, 02:06 PM
Scott S "I also like to think that in some way also i... May 13 2016, 03:51 PM
Darren C Its going to "happen" when you don't... May 13 2016, 04:34 PM
rhodyguy :flag1: :brain: :bravo3d: May 13 2016, 05:15 PM
Darren C Exactly Rhodyguy, thanks.(Is that you cutting your... May 14 2016, 06:10 AM
rhodyguy :pissoff: :mueba: :splat: May 14 2016, 06:32 AM
Darren C You're trouble. I have your card marked Banana... May 14 2016, 06:36 AM
rhodyguy :idea: :unsure: :pissoff: ... May 14 2016, 06:47 AM
somd914 I've been sitting on the sidelines after this ... May 14 2016, 06:51 AM
rhodyguy Egotistical novellas...BLOODY BRILLIANT!! ... May 14 2016, 07:25 AM
bandjoey Guys Guys Guys Guys Guys :Qarl:
Cal... May 14 2016, 09:17 AM
somd914
Ca... May 14 2016, 10:32 AM
somd914 Darren,
Fair enough, I appreciate your taking the... May 14 2016, 02:44 PM
Darren C Thanks Scott.
On a lighter note...
https://www.y... May 15 2016, 01:19 AM
rhodyguy Did you attend a public school? May 15 2016, 08:16 AM
Darren C Change of bait eh Banana-man? Maybe not so?
Like ... May 15 2016, 09:19 AM
rhodyguy That would be mr powers to you. Or Kevin. How abou... May 15 2016, 09:32 AM
Darren C What...answer that either way just so you can make... May 15 2016, 03:46 PM
SirAndy :WTF: Thread closed ... May 16 2016, 12:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:19 AM |
