Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,196 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
r_towle |
May 14 2016, 10:52 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Status!
Amphicar770 |
May 16 2016, 09:14 AM
Status! Thwarted by a $5 part. New fuel pump is in, tank is back in. For the new pump I need about 2' of 1/2 inch fuel hose between pump inlet and filter that is also used as step down. After checking a half dozen FLAPS, I wound up ordering the needed hose from RockAuto. Probably will not be here until Wednesday. Oh well, that gives me time to adjust the rear calipers. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:48 AM |
