cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Just chasing a noise on my 2.0 that sounded like an exhaust leak but doesn't look like one once the exchanger is off the head.
However I notice that the #3 port and pipes are light gray instead of black. I tightened the exhaust before taking it off with no change and it doesn't look like it was leaking there. Could leak between the head and cylinder cause it to be lean? and also go away once its warmed up? Or is this generally a problem that is cause by intake leaks? |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So, pull the heat exchanger from that side and take a good look at that exhaust port and copper gasket, if it has been loose all this time it blew out the gasket and may have blown out a groove in the head also.....thus a loud leak.
Lo-Fi Version | Time is now: 17th July 2025 - 04:36 AM |
