| rgalla9146 |
May 18 2016, 05:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Anyone here have experience with self contained 12V AC compressor ?
Mounts remote from engine, driven by electric motor. Seems it might be a way to have AC on a 6 conversion. Jegs sells them in two capacities. Pretty spendy. |
| bandjoey |
May 18 2016, 06:40 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about.
http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ |
| rgalla9146 |
May 18 2016, 07:53 PM
Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about. http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ As mentioned, sold by Jegs part # 51810 9 -30 volts, 31 amps, 3753 btu Available in two versions for small or larger cars. (specs listed are for the smaller unit) Was $1199 ...... now $749.99 Not doable with a 160 amp 911 alternator ? Has anyone here seen one installed on anything ? |
| Gunn1 |
May 18 2016, 08:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
[quote name='rgalla9146' date='May 18 2016, 08:53 PM' post='2346865']
[quote name='bandjoey' post='2346821' date='May 18 2016, 08:40 PM'] Electric AV compressors in cars use up to 230v. (IMG:style_emoticons/default/sad.gif) If you see a 12v one let us know. Several Ac threads where this has been talked about. http://www.revoltev.com/2013/08/02/the-12v...oling-solution/ [/quote] As mentioned, sold by Jegs part # 51810 9 -30 volts, 31 amps, 3753 btu Available in two versions for small or larger cars. (specs listed are for the smaller unit) Was $1199 ...... now $749.99 Not doable with a 160 amp 911 alternator ? Has anyone here seen one installed on anything ? Prob need a higher output alternator or maybe a dedicated alternator that would run just the AC, would probably still be easier than installing an old school set up |
rgalla9146 Electric AC compressor May 18 2016, 05:19 PM
whitetwinturbo :popcorn: May 18 2016, 06:12 PM
jd74914
[quote name='bandjoey' post='2346821' date='May 1... May 19 2016, 01:02 PM
barrym A few of my lotus friends have used this solution ... May 18 2016, 08:04 PM
OU812
A few of my lotus friends have used this solution... May 18 2016, 08:19 PM
jeffdon
A few of my lotus friends have used this solutio... May 19 2016, 03:14 PM
Elliot Cannon
[quote name='OU812' post='2346885' date='May 18 2... Aug 5 2016, 08:22 PM
r_towle Boating world has made some great progress in sure... May 18 2016, 09:55 PM
OU812
Boating world has made some great progress in sur... May 19 2016, 12:17 PM
Dave_Darling
In other words the power needed or used to produc... May 19 2016, 01:49 PM
boxsterfan I think McMark fitted a 130A GM alternator on a ty... May 18 2016, 10:20 PM
porschetub 230amp altenator holy...drive that ,turn the cooli... May 19 2016, 06:36 PM
Steve I am starting to see this one pop up in various th... Aug 5 2016, 12:28 AM
jim_hoyland Steve: what's your alternator put out ? How ma... Aug 5 2016, 05:49 PM
Steve
Steve: what's your alternator put out ? How m... Aug 5 2016, 05:57 PM
Series9 The answer is: NO.
I don't feel like explain... Aug 5 2016, 08:29 PM
Rand It would work about as well as a 12v electric heat... Aug 5 2016, 09:17 PM
Chris914n6 In a typical system the compressor is usually on o... Aug 5 2016, 09:55 PM
busmech Could always do this, just a bit of more air resis... Aug 5 2016, 10:29 PM
Rand Swamp cooler makes more sense than trying to power... Aug 5 2016, 10:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:11 PM |
