Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,196 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
r_towle |
May 18 2016, 09:03 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
One is not firing.
Firing order wrong would do that. Loud backfire could mean raw fuel in exhaust. That could mean one of the valves is not closing properly. So, it might feel like it's ok, but it's possible one of the push rods is not seated properly in the lifter and is sitting sort of on the edge of the cup. When the valve is closed, you should be able to reach under each rocker and Spin each push rod all the way around, easily and with no resistance....because there should be a valid gap for th tappets. Rich |
Lo-Fi Version | Time is now: 7th June 2024 - 02:23 PM |
