> Blinker Relay Question
orbit398
post May 19 2016, 09:02 AM
For some reason, the left blinkers no longer come on. I have check the bulbs and they are good. I replaced the fuses the other day and cleaned all the fuse holder contacts.
The right blinkers do come like normal. When I turn on the right blinkers, the relay works like it should. I removed the black relay cap and can see it operating properly. When I turn on the left blinkers, the relay does not work/move. The light filament in the bulbs are not on either.
Is it possible for the relay to only work for one side of the car? I figured the relay either worked or didn't work. Attached are two photos of the relay internals. The one post with a "C" designation appears to have gotten hot at some point and wonder if may be the issue.
Anyone know what the connectors are on the relay?
C =
49 =
49a =
31 =
Attached File(s)
Spoke
post May 19 2016, 10:32 AM
Jerry
Do the 4-ways work?
The relay is a single provider of power to the turnsignal bulbs for the left and right side. Only the turnsignal stalk determines which side will flash.
orbit398
post May 19 2016, 10:46 AM
QUOTE(Spoke @ May 19 2016, 11:32 AM) *
Do the 4-ways work?
Will have to check on the 4 ways when home. If they work, will that indicate I have an issue with the turn signal stalk?.
Assume if they don't work, I have a short somewhere on the left side blinkers, correct?
- Lo-Fi Version Time is now: 2nd April 2026 - 11:22 PM
