> 1975 starter issues, Starter doesn't disengage
Bryce
post Apr 20 2016, 03:42 PM
Hello guys new to this forum, but have had multiple 914s,I'm working on a 75 with starter issues. Had a friend bring his 914 to me to work on carburation etc... When he got here I when to start it and nothing so checked wiring and it was fine. Tryed jumping starter it was locked up solid. He live about 3 miles from me and stated that he did here some grinding type noises . He just had a remanufactured replacement starter installed. I told him to get another so he did same thing Bosch reman. I installed it and it's doing the same thing once you turn the key to start it, it doesn't disengage. I've changed new ignition switch new starter relay(aftermarket). I'm at a total loss, and very frustrated doing this as a friend and am over it. Any suggestions? Also I pulled starter bolts out and grounded body to run starter in the open and running or bench testing it the solenoid doesn't push out. I thank it's possessed. One other thing is he had a shop swap his injection for China 40idf carbs. Of witch they don't have any vacuum ports in them or the manifolds, should it be ok to tap into the Manifold for distributor vacuum?
stugray
post May 19 2016, 12:19 PM
I have heard of certain (aftermarket?) starters binding up like you describe if the starter body is not shimmed away from the trans case.
Does anyone recall that?
I bought an ebay high torque starter and it came with a shim.
IIRC I put it in and have zero problems.
tomrev
post May 19 2016, 12:35 PM
QUOTE(stugray @ May 19 2016, 10:19 AM) *
I also have the Hi-Torque starter, and am using a 3/16ths aluminum shim between it and the gearbox. Works perfectly. When I first read the post, I wondered it the starter was jamming the bendix into the ring gear, but with ign. key released, the solenoid should try to retract, and starter motor should be un-energized.
- Lo-Fi Version Time is now: 3rd July 2025 - 12:54 PM
