Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,193 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
Amphicar770 |
May 19 2016, 05:22 PM
Yes, I did do valve adjust after I replaced the rocket rod "tubes" and reinstalled rockers.
I have only run it briefly a few times. It has not backfired at idle since the first couple of times but did have some when I press accelerator. Missing is definitely still there even without backfire. |
stugray |
May 19 2016, 05:34 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Yes, I did do valve adjust after I replaced the rocket rod "tubes" and reinstalled rockers. I have only run it briefly a few times. It has not backfired at idle since the first couple of times but did have some when I press accelerator. Missing is definitely still there even without backfire. And what did you use to identify Top Dead Center (TDC) when you set the valves? Was the distributor installed and did you verify where it was pointing when you were at TDC #1? |
Amphicar770 |
May 19 2016, 05:38 PM
Yes, I did do valve adjust after I replaced the rocket rod "tubes" and reinstalled rockers. I have only run it briefly a few times. It has not backfired at idle since the first couple of times but did have some when I press accelerator. Missing is definitely still there even without backfire. And what did you use to identify Top Dead Center (TDC) when you set the valves? Was the distributor installed and did you verify where it was pointing when you were at TDC #1? Yes, used distributor, flywheel marks, straw in cylinder. I was pretty paranoid about having it right. Most of the valves required very minimal if any adjustment. That said, it was first time ever adjusting valves son the possibility that I mucked it up is always there. |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:45 PM |
