| orbit398 |
May 19 2016, 09:02 AM
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
For some reason, the left blinkers no longer come on. I have check the bulbs and they are good. I replaced the fuses the other day and cleaned all the fuse holder contacts.
The right blinkers do come like normal. When I turn on the right blinkers, the relay works like it should. I removed the black relay cap and can see it operating properly. When I turn on the left blinkers, the relay does not work/move. The light filament in the bulbs are not on either. Is it possible for the relay to only work for one side of the car? I figured the relay either worked or didn't work. Attached are two photos of the relay internals. The one post with a "C" designation appears to have gotten hot at some point and wonder if may be the issue. Anyone know what the connectors are on the relay? C = 49 = 49a = 31 = Attached File(s)
relay___blinker.pdf ( 307.98k )
Number of downloads: 153 |
| orbit398 |
May 19 2016, 07:29 PM
OK forum folks, any brains out there that know what the heck is going on with the car? Completely frustrated with it. I haven't had any luck yet from comments so far.No luck with left blinkers working. All used to work just fine a few days ago.
When the blinker relay is installed, when I pull out the hazards, blows the fuse, second to the last towards the interior of the car. With blinker relay installed, right side blinkers work just fine, left has nothing. With key off and I turn blinker stem to left, left front/rear and right rear parking lights come on. With blinker stem turned to right, only the front right parking light comes one. Fricken weird. Intermittently, the dash blinker comes on when I have the blinkers to the right working. It should work all the damn time. Faulty relay?????? Thinking the blinker stem switch was faulty, I tired to follow the link blow to get to the switch. Well my car is a 74 and what is described in the link doesn't work. I can't get mine to come out after removing the 4 screws. If any one has experience any of this, please let me know what you did to fix it. |
| xperu |
May 20 2016, 01:16 PM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
OK forum folks, any brains out there that know what the heck is going on with the car? Completely frustrated with it. I haven't had any luck yet from comments so far.No luck with left blinkers working. All used to work just fine a few days ago. When the blinker relay is installed, when I pull out the hazards, blows the fuse, second to the last towards the interior of the car. With blinker relay installed, right side blinkers work just fine, left has nothing. With key off and I turn blinker stem to left, left front/rear and right rear parking lights come on. With blinker stem turned to right, only the front right parking light comes one. Fricken weird. Intermittently, the dash blinker comes on when I have the blinkers to the right working. It should work all the damn time. Faulty relay?????? Thinking the blinker stem switch was faulty, I tired to follow the link blow to get to the switch. Well my car is a 74 and what is described in the link doesn't work. I can't get mine to come out after removing the 4 screws. If any one has experience any of this, please let me know what you did to fix it. I have a 74, and live in League City (FM 646 & !-45) if you want to take a look. Mike |
orbit398 Blinker Relay Question May 19 2016, 09:02 AM
Dave_Darling Also responded on your post on the Bird Board:
Wi... May 19 2016, 10:16 AM
Spoke Do the 4-ways work?
The relay is a single provide... May 19 2016, 10:32 AM
orbit398
Do the 4-ways work?
The relay is a single provid... May 19 2016, 10:46 AM
orbit398
Do the 4-ways work?
The relay is a single provi... May 19 2016, 04:15 PM
ThePaintedMan If you're jumpering each side individually and... May 19 2016, 04:25 PM
orbit398 anyone have a simple wiring diagram of the fuse pa... May 19 2016, 06:27 PM
Spoke Here's a simplified version of the turnsignal ... May 20 2016, 01:02 PM
Geezer914 Electrical problems drive me nuts. You can't ... May 20 2016, 04:30 PM
Spoke If I were debugging this, first thing to do is che... May 20 2016, 08:25 PM
orbit398 Update. - For what it's worth, may be helpful ... May 21 2016, 10:26 AM
914Mike
... Cleaned up and using a test light to the con... May 21 2016, 07:30 PM
IronHillRestorations I just waded through the same issue, except it was... May 8 2021, 10:49 AM
dax1969 mmm perhaps I should use same procedure to chase m... May 10 2021, 01:37 AM
buck toenges I had a similar problem last week with my right si... May 10 2021, 10:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:15 PM |
